Old 06-17-2013, 06:44 PM   #1
Rear MH Lights - Wiring the toad
Howdy Folks. I'm having a tow vehicle wired (for braking and turns) and the installer asked me if my MH had a one or two light system for the turn signal/brake signal. Apparently it involves some diodes, one way or the other, that need to be installed on the Toad. We have a 2012 390BH-360, and would greatly appreciate it if anyone knows the answer. Thanks.
117W33N is offline   Reply With Quote
Old 06-17-2013, 07:02 PM   #2
NV245's Avatar
If you have a trailer connector on the back of the coach, the problem is already solved, just need to know if the connector is 4 or 7(most common) way. What the installer is wanting to know is if your coach has amber turn signals and red brake lamps or if you have red brake lights that become turn signals. In newer vehicles with factory trailer wiring the trailer connector circuits already behave as if the brake/turn signals are the same, no add on diodes needed.
NV245 is offline   Reply With Quote
Old 06-17-2013, 07:03 PM   #3
Himcules's Avatar
i'm not sure i understand this?
your installer should be taking the input from the harness connect at the hitch. the harness will give the brake, braking lights, parking lights, and turn light signals through that regardless of how many lights are on the motorhome...
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 06-17-2013, 07:41 PM   #4
NV245 is correct in that the installer is asking if the Berk has the two different lamps or just one. In my case, the Toad is a 1971 FJ40 Landcruiser, so a diode setup will be required if two bulbs are in use on the Berk. I do know that the Berk has a 7 pin connector. Just need to find out if it runs one or two bulbs. The coach is in storage right now, otherwise I would just go out and kick the tires. Does anyone know the bulb setup or has had to deal with this issue themselves? Thx
Old 06-17-2013, 08:20 PM   #5
NV245's Avatar
The 7 way connector on the Berkshire, being factory Freightliner, will have as output for left turn signal, right turn signal, park lamp, and ground for the towed vehicle or trailer. The other pins should be for 12 volts, electric brakes, and reverse lamps. The turn signal outputs, when constantly on, are used as brake lamps. The connector on the coach should be wired in a universal manner so any trailed vehicle can just be plugged in. Just remember, the way the electrical system is configured, that if the coach lighting is working correctly, it doesn't mean that there couldn't be a fuse open for the towed vehicle and the toad's lights won't work. Checking the toad's lamp operation occasionally is recommended. Tell your installer that you already have the coach wired for trailer with a 7 way connector.
Old 06-17-2013, 10:28 PM   #6
As far as I know, the diodes keep the coach voltage from interfering with the toad voltage (and vice-versa) since both the toad itself as well as the coach are powering the same bulbs.
I think to run a 3 light on the toad to 2 on the coach (or vice-versa) requires more than simple diodes; but an electronic "box" that converts between one type of system and the other.
I'm not an expert on this, but I have the diodes on my toad and both the coach and toad share the same bulb filament for both turns and brakes (the old fashioned way before amber lenses came around).
Boowho??
boowho is offline   Reply With Quote
Old 06-17-2013, 10:59 PM   #7
NV245's Avatar
The diodes installed on the toad prevent front turn signals and parking lamps from operating on the toad when motorhome lamps operate. Usually a relay that only allows toad brake switch to work with toad ignition on is installed with a toad brake controller to prevent toad brake lamps from interfering with coach brake lamps when toad brake controller functions.
