Old 08-06-2016, 11:51 PM   #11
There is another source of ghost images from a side window refraction
I went out to my Berk 34QS today to install what I thought was the solution to my reflection problem. I attach a picture of the black towel behind the driver's seat. It covers the slide window behind the driver.
I didn't have the conditions to test whether it solved my problem. The problem occurs with bright light facing the front windshield and a dark space to the left of the coach into which I am backing. I didn't have the dark space.
However, I did mention that I also had noticed ghost images in my left mirror as I drive, and I assumed that they were related to the problems with the left mirror being overpowered by a reflection. Maybe they are related and maybe they aren't.
But, the big (bad?) news is that the towel doesn't get rid of the ghost images! Now we have a mystery and I looked more carefully. Obviously the ghost images aren't a reflection from the slide window and I couldn't find any other surface that would provide the reflection. I am able to identify the source of the ghost image because I can see the logo and windows on the trailer across from me.
I finally discovered that if I position a flat object like a book so that one edge is along the pillar between the windshield and left side driver window, and so that it goes back toward the driver in a manner that it doesn't block the driver's view, then the ghost image is blocked.
I'm a photographer and the necessary light path is perplexing. It has to be the case that the light enters the windshield and hits the driver's side window just behind the pillar, because my book was only blocking that light path. But, there is no way for the light to be reflected forward to the mirror. It must be refracted! That would require an incredibly high index of refraction. But, the side window might be laminated safety glass, which gives another surface for a second refraction. At any rate, the two refractions seem to turn the light by almost 90 degrees so that they hit the side mirror and reflect back to the driver.
OK, so this explanation is a bit complex, but there are three conclusions to draw from this:
1. The ghost problem can occur on a coach even if it doesn't have a forward-facing window on the slide behind the driver.
2. The ghost problem may or may not be the same as the problem that causes the side mirror to be virtually useless when backing into a dark spot. If it is not the same, my black towel solution may be all that is needed to solve the parking problem.
3. If the ghost problem is the same as the problem that makes it hard to back up, the solution is to fasten a flat vertical piece (black coroplast would be safe) with its edge along the pillar between the front windshield and the side window and aimed back at the driver in a way that does not block the driver's view. My guess is that something 6" wide by one or two feet tall would do the job.
I'll report back as to whether the towel solves the problem after my next trip.
Name:	Towel to stop reflection.jpg
Gordon Sick, Calgary
2015 Berkshire 34QS
2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
Old 08-07-2016, 08:33 AM   #12
ccupton's Avatar
Gordonsick,
On my 38A I do not have a window behind my head. There is just bad reflection off of surrounding interior. Like you I have had to stop and look where I am backing. This is an issue but how often are you backing compared to moving forward. Still looking for the right fix.
Chris & Carol
2016 Berkshire 38A
2014 Honda CRV
Chris & Carol
2016 Berkshire 38A
2014 Honda CVR
Blue Ox base plate & tow bar. Air Force one Braking system.
ccupton is offline   Reply With Quote
Old 08-07-2016, 09:28 AM   #13
tmmar's Avatar
I think that most of the problem is caused by light reflecting off the light (white) dash. If I cover the dash with a dark towel, most of the reflection is taken care of - not all of it though.
Tom and Margaret
2014 Berkshire 390bh-60
Old 08-07-2016, 09:37 AM   #14
15berkxl's Avatar
My take on this is drivers side window is picking up reflection of windshield and drivers mirror is capturing that image. How to prevent it is the million dollar question
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 08-07-2016, 09:39 AM   #15
tmmar's Avatar
I had the same issue with my '08 and that had a 2 piece windshield.
Tom and Margaret
Old 08-07-2016, 10:53 AM   #16
Campin Cajun's Avatar
Wayne
I just lower my windshield sun shade. It takes all the glare out. Works great when backing into my garage or a site.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 08-07-2016, 01:53 PM   #17
15berkxl's Avatar
That was the next thing I was going to test to see if it worked. Did you pull it all the way down below the mirror?
Wayne
Wayne
Old 08-08-2016, 01:52 PM   #18
fredhardy's Avatar
I also have encountered this issue and it is very frustrating. I often have to look down at my small curved mirror to see what I need.
Regards,
Fred
Fred Hardy
Phoenix, AZ
2014 Berkshire 390BH-60
2007 Explorer Sport Trac
fredhardy is offline   Reply With Quote
Old 08-08-2016, 08:46 PM   #19
Wayne
Yes sir I did. Works great, there's still a little reflection but most of it is gone.
Old 08-11-2016, 01:55 PM   #20
Wayne,
How low can your sunshade go when your motor is on? Mine won't go very low and the source of my reflections in the sky seems to be below my sunshade, even when lowered.
2015 Berkshire 34QS
reflection, slide
