Old 03-08-2016, 01:44 PM   #11
I figured I'd check the manual on my 2009 390BH. Here's the page with the dash lights...
Name:	ImageUploadedByForest River Forums1457466236.958430.jpg
Sorry it's sideways
Moose
2009 FR Berkshire 390BH
jbramhall is offline   Reply With Quote
Old 03-08-2016, 03:13 PM   #12
klucas's Avatar
If your berk uses def fluid you won't know it's happening unless your dpf filter is clogged and need to do a parked regen. Def fluid is used when it burns off the soot. It's also my understanding you will not get a drop in mpg since its using the def fluid for this process. I do a lot of hwy driving with my 2012 berk never had a lower mpg and never had to do a parked regen. I go thru about 1 gal of def fluid per 2-300 miles. I have 45k on it now.
klucas is offline   Reply With Quote
Old 03-08-2016, 03:49 PM   #13
MotoxDad's Avatar
All great information to know. Thanks
John
2014 Berkshire 400BH
Motocross Dad
MotoxDad is offline   Reply With Quote
Old 03-08-2016, 03:51 PM   #14
BamaBob's Avatar
Not doubting your word but, Woah! Waitamin...DEF usage is typically injected into the exhaust stream by a metering system at a rate of 2% of diesel consumption. So, to keep the math simple, 2% of 100 gal = 2gal DEF; worse case assume 9MPG** = 900 miles. So, 1 GAL DEF per 450 miles of travel.
** Some Berk owners are reporting MPG in the 10-11 range.
So now MY question is can something go screwy with the DEF injector? Is a high DEF usage rate indicative of something going wrong in the engine or exhaust systems?
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 03-08-2016, 04:49 PM   #15
klucas's Avatar
It may be more on occasion- (def usage). But I have the 360 engine and a lead foot. We mostly travel in the mountains so I don't get 10mpg.
Old 03-08-2016, 05:52 PM   #16
mikeborny's Avatar
I need to fill my DEF tank every three fill-ups
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 03-09-2016, 07:53 AM   #17
I-RV's Avatar
Originally Posted by MotoxDad View Post
Has anyone had an issue with ever having to do a regen? If so what steps did u complete to do a regen? Just curious if it is something I should lookout for in the future.
John - Regen most of the time happens automatically. However with certain driving habits, like always short trips, you will be alerted on the dash to do a manual Regen. There is several alert severity levels. A high severity level will incapacitate the RV from moving.
An excellent past thread on this explains regen.
Regen switch
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
