Thanks Dave. My tail lights are two units 3 bulbs each, for a total of 6 bulbs: 4 signals and two backup. So, we might be talking about a different tail light.
I wonder if you have an older unit.
I should have sent pictures in the original post, so here are 3 pictures. The first is the unit from outside, where it appears to consist of two truck tail light assemblies on each side. The second shows the inside and the third shows a closeup of the connector that I wanted to disconnect.
The second picture shows 4 Philips screws plus 4 hex studs, that look like they are intended to plug into something. I'm suspecting that I'm supposed to undo all these screws and studs, and then find the long panel inside coming out. I assume that it comes off and then I can access the bulbs.
So far, I don't have bulbs burnt out, but I did have the assembly off and became curious about what to do when one burns out.
cheers, Gordon
