Old 06-30-2014, 06:00 PM   #21
Berkshire 390QS
NO3putt's Avatar
Phil, are you missing the center cap or is it just off?
Old 06-30-2014, 06:04 PM   #22
Berkshire club
Berkshire Driver's Avatar
get this to remove the wheel chrome lug nut covers without damaging or pickup a dozen at your truck stop for spares they damage easily mostly loose and fall off
also look close at your wheel studs for a (R) right hand or (L) Left hand before trying to remove just FYI
2014 360QL-60 Mystic Garnet
Berkshire Driver is offline   Reply With Quote
Old 06-30-2014, 06:04 PM   #23
glevron's Avatar
Had the same problem with mine, used a pipe wrench on the T-wrench & finally got it to move. Pretty rusty when I got it off. 2014 390RB, Put it back on with never seize.
glevron is offline   Reply With Quote
Old 06-30-2014, 06:07 PM   #24
I am still looking for someone that has more tools. I have 1.25 socket with me but nothing larger.
Old 06-30-2014, 06:07 PM   #25
2011 Berkshire 390BH
Superchief's Avatar
Phil, I got extra wheel covers, if you damage those getting them off. Craig
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 06-30-2014, 06:17 PM   #26
I've all but ruined the lug now. I don't understand why I can't get any if the four off. I've done a fair amount of wrenching so it's not like I'm a DA or anything well I am kinda a DA but I can almost always get three off and the last one gives me trouble. All four what did they put them on with.
I'm going to the tire store and putting new rims on. Sick if this crap. The reason I have to remove the covers is the valve steam isn't close to lining up with the hole. It's always been a pain to adjust air in the tires and I had to buy a air chuck to get to it at all. Done.
Thanks for the advice.
Old 06-30-2014, 06:29 PM   #27
NV245's Avatar
Socket is a 1 9/16. I purchased one at TSC (Tractor Supply) with a 3/4 to 1/2 adaptor for less than $20. I keep it with the coach tools. The plier set, sorry to say, will not work and could ruin the cover (guess how I know).
NV245 is offline   Reply With Quote
Old 06-30-2014, 06:40 PM   #28
Phil, there will only be two lug nuts that will come loose to take the wheel cover off. They will be directly across the wheel bearing from each other. There will be a small raised rib on each of the nuts, that will be the ones that need to be removed. I might suggest you get maybe a 3 inch valve stem extension, sure will make it easier access to the valve stem. The fronts are easy access, remove with a channel lock or large vise grip both with electric, duct tape or you rag technique. Rears I have found that vise grips work better. They really should not be that tight...good luck...
RodneyD is offline   Reply With Quote
Old 06-30-2014, 07:43 PM   #29
Rodney thanks for the info. I identified the correct lugs and for anyone wondering they have a long dimple on them. You can feel the difference if you reach a finger in the hole.
Like I said they will not come loose. If I had a ratchet with the socket 1 9/16 I could use a breaker bar and get it. I don't have that and shouldn't need it to get them off. Like I said by this time tomorrow I will have some shinny new rims on the MH. I should have done it last year. They look better and they don't have @&$& covers.
Old 06-30-2014, 07:58 PM   #30
NV245's Avatar
Name:	ImageUploadedByForest River Forums1404176245.872168.jpg
ID:	56837. Easy this way, just drive forward.
cover, wheel
