Old 06-30-2014, 03:20 PM   #1
Removing wheel cover
Stupid question but how do you remove the wheel cover ? I thought the fake lug with the dimple held them on. No go have tried everything.
Old 06-30-2014, 03:22 PM   #2
JTN8's Avatar
I have two of them on each cover. Take them off and entire wheel cover comes off.
Jason
Old 06-30-2014, 03:25 PM   #3
I can't budge the &$@ things.
Old 06-30-2014, 03:27 PM   #4
JTN8's Avatar
I usually place a rag over it and then use a large wrench and it works without scratching them. That is for my front ones... I've yet to remove my rear ones yet, but would assume they're the same
Old 06-30-2014, 03:31 PM   #5
My largest wrench I have here is 11/4. I have the T wrench but it's to big. I'll try the rag idea under it.
Old 06-30-2014, 03:37 PM   #6
JTN8's Avatar
When they took my covers off my last motorhome to rotate tires, I watched them use large vice grips with a rag. Worked for them so that's where I got the idea of the rag so they wouldn't scratch the Nuts.
Old 06-30-2014, 03:39 PM   #7
I'll have to go get some grips. Most of my tools are in storage.
Old 06-30-2014, 03:41 PM   #8
tmmar's Avatar
Phil,
Weren't your wheels, tires and air bags upgraded by Forest River? If so, do you should have aluminum wheels. If you have aluminum wheels, then you need to remove the chrome caps over each lug nut by pulling them off with a pair of pliers or maybe even just by hand.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-30-2014, 04:03 PM   #9
Tom I still have the wheel covers. They wanted 1500$ to upgrade them and I'm to cheap. I borrowed some channel locks and got a good grip. They won't budge. I tried all four and no go. Gaffney must have put them in with a impact wrench and lock tight. They just won't move.
Old 06-30-2014, 04:39 PM   #10
Berkshire 390QS
NO3putt's Avatar
Dicor sell the "T" wrench for the simulators and can be ordered for about $10 or so.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 06-30-2014, 04:44 PM   #11
My MH came with one but it's a POS. I put channel locks on it and used my foot to push down no go. I beat the locks with the hammer and still no go. I thought it might be left hand threads but it won't go.
Old 06-30-2014, 05:01 PM   #12
Campin Cajun's Avatar
They are pretty stout covers. If you have to try using a 24" pipe wrench. I'm floored that they didn't budge with a foot and channel locks. Wow that's on there. Good luck.
2013 Berkshire 390 BH
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 06-30-2014, 05:14 PM   #13
I'm so PO'd at these covers. I have one more idea and I would guess that the nuts will be junk by the time I get them off. I called a truck tire dealer and I think I'll have aluminum wheels put in tomorrow. All I wanted to do was put my new TPMS on and I can't get them on with out removing the covers.
Old 06-30-2014, 05:22 PM   #14
Ford Idaho's Avatar
Would you mind posting a couple of pictures of what you are dealing with?
Old 06-30-2014, 05:31 PM   #15
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Are you still over by the lake shore? I'd like to come over and "help" if you moved back closer to town. I heard you were talking about me behind my back again last week.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
Lloydg is offline   Reply With Quote
Old 06-30-2014, 05:43 PM   #16
Lloyd that must have been Dick getting in the rum again. I'm down at Hidden Ridge. Here is a picture. It's not anything compacted its straight forward ro move the two fake lugs and the wheel cover comes off. The problem is they don't want to turn and I'm limited on tools here.
Old 06-30-2014, 05:44 PM   #17
AClick image for larger version
Name:	ImageUploadedByForest River Forums1404168227.574215.jpg
Darn wheel covers.
Old 06-30-2014, 05:45 PM   #18
Lloydg's Avatar
Dick sure likes that rum and Coke! Your picture did not post. opps. the picture came after I posted this
Old 06-30-2014, 05:54 PM   #19
Ford Idaho's Avatar
That looks like the type you pry off with a big screw driver or a pry bar.
Looking down right next to the tire can you see a thin gap between the cover and wheel?
Old 06-30-2014, 05:55 PM   #20
Lloydg's Avatar
It seems to me that if you try to loosen those nuts with a T wrench that is too large and try to make it work with a stuffed rag, you'll only ruin the flats on the nuts and will only compound your problem. I would try a half inch socket that fits properly and place a pipe on the end of the wrench for more leverage. Is there anyone at the park you're at that can help in the tool department?
cover, wheel
