Old 07-13-2013, 01:13 PM   #1
Mbh818's Avatar
Replace a fog light?
Anybody know the trick to replacing the bulb in a fog light? Can't seem to figure it out. Tried fruitlessly for 20 minutes.
Thanks for the help.
Mike
Mike Hollar
2014 Berkshire 390BH-40
2012 Chevy Equinox - TOAD
Mbh818 is offline   Reply With Quote
Old 07-13-2013, 11:09 PM   #2
2011 Berkshire 390BH-60
TaterColo's Avatar
Wish I could help mine are still working.
TaterColo is offline   Reply With Quote
Old 07-13-2013, 11:29 PM   #3
Himcules's Avatar
did you try to pull the generator slide out and then get in under the front of the bus?
i did not look carefully at the fog lights but i do remember i had full access to the back side of them and all their mounting screws when i had the generator slid all the way out...
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 07-14-2013, 07:34 AM   #4
billygo3251's Avatar
Which switch turns on the fog lights?
billygo3251 is offline   Reply With Quote
Old 07-14-2013, 09:02 AM   #5
tmmar's Avatar
To turn the fog lights on, you pull up on the switch that turns the headlights on when the headlights are on. Can't turn them on by themselves. Not sure how to change the bulb.
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-14-2013, 11:49 AM   #6
EJM4's Avatar
On my 2013, you press the light switch for the head lights and it will turn the fog lights on / off.
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 07-14-2013, 04:51 PM   #7
Mbh818's Avatar
To turn my fog lights on, i push down on the headlight switch. I'll see if i can access it from the generator bay. Thanks for the replies/thoughts.
Mike Hollar
