11-25-2018, 09:55 PM
Replaced Magnum Inverter Remote Control
I finally replaced my factory installed inverter remote control (idiot light version) with the new ME-RC remote control....
Talk about a major difference!!!! Love the information I’m now able to obtain....
Old Remote
New Remote
11-27-2018, 05:58 AM
Hahahahaha, that old remote looks like you had to really pound on it to get it to work. Nice upgrade.
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
11-27-2018, 08:00 AM
yes, our coach came with the ME-RC and I couldn't imagine having only the simplified 'other' version... as the ME-RC gives you so much more information, control, and troubleshooting data - including the AGS setup, Fault codes, and even internal inverter Temperatures, as well as the normal DC Volts for battery levels.
The Turners...
11-27-2018, 11:29 AM
I got mine from Inverter Supply - $134.00.....
11-27-2018, 11:30 AM
CZNEDY.....
Just many years of use....
11-27-2018, 04:30 PM
Earnest - I read the operations manual this past summer and was blown away with the settings and information it presents. I changed some of settings immediately.
Regards,
Fred
11-27-2018, 05:49 PM
Fred.....
I did also..... I find it interesting to be able to see how many amps I'm using at any given time..... I most likely will be adding the AGS feature to my system this Spring because I see it
11-27-2018, 05:50 PM
as something I can use.....
11-27-2018, 10:11 PM
yeeeeeaaaa buddy! you're in business now.
2019 34QS with no ladder!
11-28-2018, 12:56 AM
Dragonship Captain
Originally Posted by ernest917
Fred.....
Not so fast.. .. The amps you are seeing are the amps the INVERTER is using.... Interior/exterior lighting, furnace blower etc are in addition to that.
In order to see ALL the amps you are using you need to add a BMK... Battery monitor kit, which will ADD this data to the remote.... Good news is that it is (almost) plug and play.
Read about it (and a lot of other info on your 12V system) here: https://dragonship.blog/battery-monitoring-kit/
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
12-19-2018, 10:33 AM
Was is a direct replacement?
12-19-2018, 11:21 AM
Yep...... unplug the old one, enlarge the wall cut-out, plug in the new one and its done... (except for adjusting a few settings)
12-19-2018, 12:27 PM
Oscar, That's something I've thought about doing. Our rigs are practically identical. I'm not an electrician but can follow instructions so how much time to do this install?
12-19-2018, 12:30 PM
….that is to add the BMK.
12-23-2018, 04:28 AM
Dragonship Captain
If you have it all ready to go (including tools) a few hours. I took my time and spent about 4, including playing around with it after it was hooked up.
12-23-2018, 12:34 PM
2011 Berkshire 390BH
Installed Yourself?
I too have have the old model, that really tells me nothing. Ended up having to replace inverter last year -- maybe age related, since my coach is 2011, or a surge (something "fried" a hookup) -- and also got a Hughes power conditioner/surge protector. I like the idea of having some real information from he newer model.
Did you did the install yourself? If so, was it difficult?
12-23-2018, 03:02 PM
Simple install..... just need to enlarge hole in wall then simply plug it in and it automatically downloads info...
You’ll need to tweak a couple of the setting but no big deal..
