Old 03-04-2019, 10:40 AM   #1
Replacement Drawer latches - 2013 Berkshire
I picked some of these up at an RV store some years back, but can't find them again. Anyone have a part number for these drawer latches from BRD Supply?
Better yet, a suggestion for a resilient & reliable alternative as these things don't really last.
Thanks,
Larry
2013 Berkshire 390FL
Plano, TX
2014 Flagstaff V-Lite 26WRB towed by a 2009 Ford F-150 Lariat 5.4L
ldnail is offline   Reply With Quote
Old 03-04-2019, 10:42 AM   #2
David N Dianna's Avatar
We went with the child safety latches, easy to install and easy to operate. they can be found at any hardware store.
2018 Sonoma 201 Mt Edition
2003 Ram 4x4 2500 Cummns
David N Dianna is offline   Reply With Quote
Old 03-04-2019, 10:49 AM   #3
We replaced ours with a better quality set from a hardware store. Took the worn out ones along to make sure the holes would align. Even the store carried two or three levels of quality it seemed.
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 03-04-2019, 03:28 PM   #4
Great idea. Going to pick up some of those 'magnetic' release ones.
Thanks.
Plano, TX
Old 03-04-2019, 07:35 PM   #5
That time of the year again and I'm ready to replace several more broken latches. I found a reference on the "Wheelingit" 2012blog about all metal adjustable tension ball latch: https://wheelingit.us/2012/11/24/eas...rawer-latches/
I found a vendor that has several sizes of these brass latches on line. Price is comparable to plastic parts. Although not a direct replacement, I will be ordering several to give them a try.
Van-Sulli is offline   Reply With Quote
Old 03-05-2019, 02:00 PM   #6
Talking
I'll give you mine. Brand new camper and it broke second trip. It's the only one in the whole darned thing. All of the others are the 'pinch clamp' style. Go figure.
David and Vicki
8 year old Springer rescue Sydney
2018 Silverado LTZ 3500HD Dually Crew Cab Duramax/Allison stock "Polar Bear"
2019 Grand Design Reflection 337RLS "The Dog House II"
Andersen Ultimate 5th wheel hitch
EezTire TPMS
Springerdad is offline   Reply With Quote
Old 03-05-2019, 03:19 PM   #7
jmgllt's Avatar
Look on amazon under RV cabinet latches
jmgllt is offline   Reply With Quote
Old 03-05-2019, 03:45 PM   #8
Universal brand. Part number #H316 push latch by RV Design. Not cheap for a couple of plastic it seems to me. Found them at an rv place in Laughlin and they wanted $15.95 there for them. I’m certain they can be had for less. Three other places checked along the way didn’t carry them.
Old 03-05-2019, 03:53 PM   #9
Erinn
THANKS for sharing! We are only 6 mos old (our 2018 Sunseeker) & have already had to have dealer replace TWO drawer latches! I've already printed the article & will SAVE it, for when we need to replace the next ones. Cheers!
SunseekerFunseekers is offline   Reply With Quote
Old 03-23-2019, 06:01 PM   #10
BobbyJ
Bobbyj's Avatar
These are called “Grabber Latches”. You can find good quality latches on Amazon. FR uses cheap Chinese versions that don’t work. Get the Southco 10 lb - 44 newton variety.
Bobbyj is offline   Reply With Quote
2013, berkshire, replacement
