Old 07-23-2015, 06:52 PM   #21
Hallen01's Avatar
Area 51,
I don't understand why you still have the smaller tires if you had the front air bag/larger tire upgrade that FR does/did free of charge (not an official recall) for those units affected (recent years). If you have difficulty staying anywhere near the front axle weight limit (FGAWR) and/or your Berk handles like a double bed with a full tank of fuel, then call the Warranty Dept at FR Diesel.
The FGAWR was, I believe, 10,410 lbs. After the ugrade, it became 12,000 lbs. Typical FA operating weights are closer to 11,000 with two persons and modest cargo in the bays.
You can easily find the thread on this, as it was quite extensive, and affected a lot of folks.
Hallen01 is offline   Reply With Quote
Old 08-14-2015, 12:40 PM   #22
Just Dreamin
dreamin533's Avatar
Hi All, I just wanted to throw in my 2 cents. I have a 2008 Berkshire 360QS and I am replacing my tires next spring. I went to tire dealer here in Kingston, Ontario and got some good information on the Michelin 255/80R 22.5 tires, they are equivalent to 14 ply tires so you have to run higher tire pressures (105-110 psi) to carry the weight of the coach and tow vehicle. It was recommended by them to go to 275/70R 22.5 tires, which can be have ratings equivalent to a 16 or 18 ply tire. I am putting on a set of Hancook's (AH12) which are 16 ply and will carry the weight of the coach (29,410 lbs) and tow vehicle (up to 10,000 lbs) while only running 90-95 psi. The best thing is $2700.00 installed and balanced for 6. The other option is the Firestone FS560 which would be $3000.00 out the door. Up here the Michelin's are running around $580.00 per tire and Michelin is the only company that makes the 255/80R 22.5 tires. Good luck to all on the tire issue. Roy
dreamin533 is offline   Reply With Quote
Old 08-14-2015, 02:45 PM   #23
7 Year Class A RV'er
Wow! That's a good price, especially if that's Canadian $! I bought a set of 19.5 Goodyear tires for our last RV about 4 years ago and they ran me over $3,000 mounted and balanced. Hankook is a good tire - my wife has them on her Explorer and they give great ride and performance. I didn't even know they made RV tires - have to check into that when it's time for new ones on the new RV. Thanks.
2015 Legacy SR340 360RB
Old 08-14-2015, 02:54 PM   #24
I have always had good luck with good years. My 2015 came with good years. The only tire on a motor home I had problems with were Michlein. Several times.
uralman is offline   Reply With Quote
Old 08-14-2015, 03:11 PM   #25
All new Berkshires will have Michelin's. FL is none with the GY contract and went back to Michelins.
Old 08-14-2015, 03:50 PM   #26
accumack's Avatar
You couldn't pay me to have Good Years. They don't wear well, handle, or ride worth a darn. I had Eagle GTs, Aqua Treads, and Wranglers I hated all of them!
Just my $.02 worth.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
replacement, tire, tires
