Adding some updates to this thread.
The Glass shop I'm using couldn't remove all the screws around that dash panel. The only way I could access them was to remove the side dash top panel and go in with a right angle drill and drill some access holes into that side dash panel and pull the screws out that way. It worked fine and the access holes aren't really visible since that dash panel is butted up against the window frame very tightly.
I thought that was the hard part and the glass shop said they were comfortable taking down the cabinet, but now they're balking at that. I'm going to have to remove the cabinet and wondering what is involved with that. My 390QS has a side cabinet directly above the drivers side window, which appears connected to the cabinet that runs across the front of the coach and over to the passenger side cabinet. Is this one complete unit that has to be removed, or can I just remove the driver's side cabinet? I'd post some pictures but the coach is at the window shop now. I may have to go there this weekend to remove the cabinet for them if I can. I thought I could drill some access holes again in the cabinet side panel but the glass shop is saying there's some thick cabinet frame material covering the window screws which rules out drilling access holes. Any help/guidance is greatly appreciated.
___________________
Bikerscol (bicycle)
2010 Berkshire 390QS
Toad - 2017 Honda Fit
