Old 12-03-2015, 08:34 AM   #91
gasman94's Avatar
Originally Posted by klucas View Post
What is a make and model number for the residential fridge swap out. I have a 2012 390bh. I would really like to get rid of that dometic I have.
Klucas, in addition to fridge you will also probably need a bigger inverter unless you already have that capacity. Residential fridge options usually include a 2000 watt inverter upgrade.
Rich
gasman94 is offline   Reply With Quote
Old 12-03-2015, 08:43 AM   #92
klucas's Avatar
Thank you for the info. I don't have the larger inverter. We don't do any dry camping and usually run the generator while driving. I am assuming that will be ok. Any advice on getting the unit in the coach and any tips on making installation easier?
klucas is offline   Reply With Quote
Old 12-03-2015, 08:55 AM   #93
gasman94's Avatar
I really don't know anything about the swap, but with the question posed, I think that their are enough people on the forum that can help. Anyone have any advice here?
Rich
Old 12-03-2015, 09:13 AM   #94
tmmar's Avatar
If you do a search you should find at least one thread on this. I think that one poster removed the window over the sofa and brought it in that way. If I remember correctly, another posted that they removed doors and took out the freezer draw and was able to get it in through the door. They said it took 2 guys to do it and had to maneuver it around to get it in. Don't remember if they had to take out the passenger seat but if you go that route, I think that I would so that it makes it easier to get in and you won't damage the seat. This is just my recollection of their posts. Hopefully you will be able to find the original posts.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 12-03-2015, 12:05 PM   #95
VinceU's Avatar
Originally Posted by tmmar View Post
Vince,
Did yours come that way or were the straps installed later? If installed later, who did the install?
Yes furnished that way, no movement.
Old 12-03-2015, 12:57 PM   #96
BamaBob's Avatar
Originally Posted by Paulie Boy View Post
Canoes tip more often������
Paul
Now that's funny right there I don't care who you are. That there is funny.
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 12-03-2015, 02:15 PM   #97
klucas's Avatar
That's an expensive fridge. I priced it at about 3k.
Old 12-03-2015, 02:54 PM   #98
gasman94's Avatar
Did you check with FR or Whirlpool?
Rich
Old 12-03-2015, 03:24 PM   #99
klucas's Avatar
What is the email for parts person at Forrest river. I have Randy's info but I don't think he would handle parts.
Old 12-03-2015, 03:28 PM   #100
Well it depends on what Moho model you have. I had my Dometic replaced this year and it is a booger. They used the drivers side living room window for access. I have a 2011 RB. They also had to Denice the cabinets over the window and also the cornices. Removed the door to the fridge and handed it out the window onto a fork truck. Removing the cabinet was a PIA. Once in people do different things to power it. The simplest is to just run the fridge when plugged in or run the gen when driving. Second is buy a inverter and wire it in behind the fridge so it is stand alone and only for the fridge. Third is to rewrite the plug already there so it is running off the existing inverter. And last install a new inverter and run power to the plug behind the fridge. I'm sure there are more options but those are the ones I found when I was considering making that change.
fridge
