Old 12-03-2015, 05:14 PM   #101
dan-nickie's Avatar
Originally Posted by VinceU View Post
Attachment 95454
Tom here's two straps on top of res fridge that should answer your question. The bars flange up at outside wall and flange down on fridge casing below hinge upper caps.
Is that a Berkshire with the Whirlpool fridge?
Doesn't look anything like mine up there.
I don't have that much room up there.
And my Fridge color is stainless.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 12-03-2015, 05:43 PM   #102
Name:	ImageUploadedByForest River Forums1449182622.782613.jpg
Andy is the parts guy at FR
Paul
Paulie Boy is offline   Reply With Quote
Old 12-03-2015, 05:45 PM   #103
Everything except the doors are gray.
Paul
Old 12-03-2015, 06:09 PM   #104
klucas's Avatar
Thank you Paul for the contact info.
klucas is offline   Reply With Quote
Old 12-03-2015, 06:53 PM   #105
VinceU's Avatar
Yes that is the "stainless clad" standard 2 door with freezer drawer about 21 cu ft. cap. The RV is a Itasca Ellipse.
Old 12-03-2015, 07:07 PM   #106
mikeborny's Avatar
I use a piece of velcro tape around the handles and a long piece to secure the freezer door shut. You could also add a long piece of velcro tape across the top to secure while driving.
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 12-03-2015, 07:17 PM   #107
Using Velcro or supplied Bungee Straps on a Residential Fridge is real close to Duck Tape! There is a Proper SS latch system that F/R should install/use! They went Mickey Mouse on the straps! Youroo!!
Old 12-03-2015, 07:33 PM   #108
AquaMan's Avatar
I saw the the latch solution, but not that impressed to drill and run screws through the doors and have the possibility of interference of the strike plate and door. The Velcro strap is quick, only needed when traveling, and won't leave any mark on fridge.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 12-03-2015, 08:07 PM   #109
gasman94's Avatar
Did mine. Placed pics for placement of striker plate on door on earlier post. Looks good. No interference. Maintains a solid closure. But I must admit that I was a little apprehensive about drilling into the door as well.
Rich
gasman94 is offline   Reply With Quote
Old 12-08-2015, 06:55 PM   #110
fredhardy's Avatar
Hello all! I purchased the recommended latch from Amazon and installed it today! A little layout work, a little drilling, 5 screws and it was done. I installed it just below the tops of the hand pulls like Paulie Boy. Looks nice and clean! Much nicer than my bungie cord!
5456Mich - the sheet metal is thin gauge material and easy to drill. I marked my locations with a pointed punch so the drill wouldn't wander. There is foam insulation beneath the sheet metal
Fred
Fred Hardy
Phoenix, AZ
2014 Berkshire 390BH-60
2007 Explorer Sport Trac
fredhardy is offline   Reply With Quote
fridge
