12-03-2015, 05:14 PM
#101
Originally Posted by VinceU
Attachment 95454
Tom here's two straps on top of res fridge that should answer your question. The bars flange up at outside wall and flange down on fridge casing below hinge upper caps.
Is that a Berkshire with the Whirlpool fridge?
Doesn't look anything like mine up there.
I don't have that much room up there.
And my Fridge color is stainless.
Dan
2014 Berkshire 390RB-60
12-03-2015, 05:43 PM
#102
Andy is the parts guy at FR
Paul
12-03-2015, 05:45 PM
#103
Everything except the doors are gray.
Paul
12-03-2015, 06:09 PM
#104
Thank you Paul for the contact info.
12-03-2015, 06:53 PM
#105
Yes that is the "stainless clad" standard 2 door with freezer drawer about 21 cu ft. cap. The RV is a Itasca Ellipse.
12-03-2015, 07:07 PM
#106
I use a piece of velcro tape around the handles and a long piece to secure the freezer door shut. You could also add a long piece of velcro tape across the top to secure while driving.
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
12-03-2015, 07:17 PM
#107
Using Velcro or supplied Bungee Straps on a Residential Fridge is real close to Duck Tape! There is a Proper SS latch system that F/R should install/use! They went Mickey Mouse on the straps! Youroo!!
12-03-2015, 07:33 PM
#108
I saw the the latch solution, but not that impressed to drill and run screws through the doors and have the possibility of interference of the strike plate and door. The Velcro strap is quick, only needed when traveling, and won't leave any mark on fridge.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
12-03-2015, 08:07 PM
#109
Did mine. Placed pics for placement of striker plate on door on earlier post. Looks good. No interference. Maintains a solid closure. But I must admit that I was a little apprehensive about drilling into the door as well.
Rich
12-08-2015, 06:55 PM
#110
Hello all! I purchased the recommended latch from Amazon and installed it today! A little layout work, a little drilling, 5 screws and it was done. I installed it just below the tops of the hand pulls like Paulie Boy. Looks nice and clean! Much nicer than my bungie cord!
5456Mich - the sheet metal is thin gauge material and easy to drill. I marked my locations with a pointed punch so the drill wouldn't wander. There is foam insulation beneath the sheet metal
Fred
Fred Hardy
Phoenix, AZ
2014 Berkshire 390BH-60
2007 Explorer Sport Trac
12-08-2015, 07:38 PM
#111
The thin material is a hesitant point from me doing the latch. I have kids that automatically just open the door and if it doesn't open easily, they pull harder! I can just see them pulling the latch completely out of the door and messing up everything. At least the velcro strap I have around the handles is easily visible.
12-08-2015, 07:45 PM
#112
That makes sense.
Rich
12-09-2015, 08:21 AM
#113
I still use the bungee cord around the handles. It's only there when we travel and you don't see it when we are parked so it's not unsightly at all.
Tom and Margaret
2014 Berkshire 390bh-60
12-09-2015, 08:28 AM
#114
Same here too. Works rather well. $.59 or $26. That bungee looks and works rather good with my fixed income. Ha
Russell
12-09-2015, 09:06 AM
#115
We have the bungees that came stock, but on our first trip we had a couple 12 packs of soda in the fridge and when I went around a sharp corner the sodas would slide against door and still pop them open (but not completely). The Velcro strap holds the door more securely.
12-09-2015, 05:07 PM
#116
This works great too and comes off easy
Wayne
Wayne
12-09-2015, 05:24 PM
#117
Originally Posted by 15berkxl
Seen something similar to this before and had given it some thought, may still do it.
Joe & Lori
2014 Berkshire 390 RB-40
12-09-2015, 06:42 PM
#118
What is it made with Wayne ? Plywood??
Russell
12-09-2015, 07:08 PM
#119
Residential Fridge
Russell Yes two 3/4 in cabinet grade glued and screwed together. FR likes it.
Wayne
Wayne
12-09-2015, 07:11 PM
#120
Joe that's where I got the idea on this forum I just improved on a good idea.
Wayne
Wayne
