Old 06-06-2015, 09:52 AM   #11
15berkxl's Avatar
Understand your post not finding fault with it or your reason just adding what I know about it for information only. Appliance manufactures will try to find any reason to save from paying a warranty claim even if the fault is unrelated to the problem. Again according to my sources and dealing with the appliance industry for many years.
Any latch to keep the product doors from opening in motion is great I just don't want anyone from being bit by the manufacture without checking into it first.
Unrelated to the latch I was told that because MH manufactures add the fixture at the bottom to keep the fridge from moving if you have to have service done on it you must first remove the fridge from the mounting and roll it out away from its normal position crazy.
Wayne
15berkxl is offline   Reply With Quote
Old 06-10-2015, 07:09 PM   #12
Kelsma03's Avatar
YES! Thank you! I saw these on Winnebago coaches at the Phoenix Good Sam Rally and have been wanting to find one for our fridge since then. The bungee cord method has failed us a few times, plus it's a pain to hook that up.
Ed and Jaime, 3 kids, 2 greyhounds
2014 Berkshire 400BH
TOAD: 2002 Ford Explorer
Kelsma03 is offline   Reply With Quote
Old 06-11-2015, 09:12 AM   #13
Kelsma03's Avatar
Before I order this, does this come with installation instructions or may I ask how you installed yours? My husband just started at me when I said I think he'd have to drill into our fridge (drilling holes in stainless steel is not one of his strong suits).
Old 06-11-2015, 10:27 AM   #14
I don't have a res fridge but was just passing on info. I wouldn't hesitate to install one if I did. Put a piece of tape on the bit so you don't go to deep. U.S. A bit for SS but this is a very thin SS sheet so it should be easy to drill. I would dap the hole with silicone and install the screws. It should be a simple install. I don't know if it comes wit instructions or not.
Old 06-11-2015, 10:35 AM   #15
Kelsma03's Avatar
Thanks. I think we'll order it and give it a try. I'd much rather have this than the bungee cord contraption we have going now.
Old 06-11-2015, 10:44 AM   #16
tmmar's Avatar
I would be very leery drilling into the refrigerator. Don't know what is in the doors as far as wires or tubes. But that said, I don't believe the refrigerators we have are stainless steel. I think they are stainless colored steel. I have a thermometer which shows the temperature inside the refrigerator and freezer and it is held on to the door by magnets. True stainless steel is non-magnetic, which make me believe that it is not true stainless steel.
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-11-2015, 12:02 PM   #17
If not SS just drill through the steel she'll. I would guess a 1/16 of a inch and again put a piece of tape 1/16 inch from the end if the drill bit to control depth. Nothing is in the door closes to the edge and you won't hurt anything. As I showed pictures the Manufacturer's are putting this same latch on residential fridges. Use a little silicone to reseal the hole.
Old 06-11-2015, 12:04 PM   #18
SS come in several different grades. The better the grade the less magnetic it is. I would guess judging from all the pictures held by magnets on our fridge it's a low grade SS.
Old 06-11-2015, 05:20 PM   #19
dan-nickie's Avatar
So, how would we use this on the bottom freezer door?
Any ideas?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-11-2015, 09:58 PM   #20
Dan it looked like the same latch mounted on the side. I didn't get a picture of that. Stop at a dealer and check one out. I think it was a Integra or a Tuscany that I saw them in.
door, refrigerator
