Old 04-30-2014, 07:57 PM   #11
Cyclone
beipers's Avatar
I'd be interested in a picture from someone using a lift on the hitch. I'm pulling a 1500 Chevy LT crew cab with blue ox mounts and a Aventa II tow bar. I'm perfectly level to slightly low. I've tried installing my 2" riser / doubler but can't the gusset hits the fiberglass.
Sent from my SCH-R530U using Forest River Forums mobile app
2015 SOB 5th Wheel
2013 Chevrolet 3500 CC, DD SRW
1 Wife, 2 Kids under 5
Camping nights: 2015 - 19, 2014 - 39, 2013 - 48
beipers is offline   Reply With Quote
Old 04-30-2014, 10:16 PM   #12
Campin Cajun's Avatar
Roadmaster Falcon A/T on my Berkshire
I had to use an 6" extension to be able to use my 6" rise adaptor. I'll get a pic of my set up tomorrow and upload it here.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 04-30-2014, 11:31 PM   #13
Gottawonder's Avatar
Thanks to all for the input... I have a 2" rise arriving Saturday. That'll put me "in the safe zone" but not fully level... Once I line it all up, I may throw in the towel and go to the 6" extension and a 4" lift, per Campin Cajun's suggestion.
My Jeep is automatic as well. They even quit installing steering wheel locks a year or so ago, so you don't have to leave a key in the ignition.
2014 Berkshire 390RB-60
2014 Jeep Wrangler Unlimited
Roadmaster Falcon A/T tow bar
Gottawonder is offline   Reply With Quote
Old 05-01-2014, 11:15 AM   #14
Here's a pic of my set up.
Name:	ImageUploadedByForest River Forums1398960938.418090.jpg
Old 05-01-2014, 11:42 AM   #15
Thanks CC, that's probably what I'll wind up doing with a 4"
This is also why I ripped the page with "Simple" out of the dictionary about 8 yrs ago.
Gottawonder
Old 05-01-2014, 12:40 PM   #16
Cyclone
beipers's Avatar
So, CC.... are you at all concerned with the reductions in towing and tongue weight that the extension manufactures suggest?
2015 SOB 5th Wheel
Old 05-01-2014, 02:49 PM   #17
This DEMCO hi/low isn't cheap but it looks like it may have more extension to it...
Demco 9523059 4 Inch Drop Raise Receiver - General RV Store
I'm thinking the 2" will be "okay" but 4" is probably gonna be optimum for my rig... I'm in over $200k already, I don't see letting another $50 get in the way of an optimum setup
Old 05-01-2014, 06:15 PM   #18
Not at all, I called e-trailer before I bought it because I read that it reduces the hitch by half using the extension. I was thinking if it did that then no way I could use one. But the way it was explained to me was it does reduce the towing hitch by half, but since my hitch is rated for 10k I'm good to go. My coach can only tow 5k. As far as tongue wt, there really isn't any while towing 4 down. I don't use the extension when towing my utility trailer and golf cart.
Old 05-05-2014, 06:49 PM   #19
UPDATE:
Checked the RV a few places and the Jeep as well... center of receiver on RV was 15" center of the pins for the tow bar was 20.5" ... made a six inch riser optimum. Made a trip with the RV up to my local hitch guru, and I even discussed moving the factory hitch back an inch or 2...then we grabbed a Roadmaster 6" hi/low (model 076)
Missed by about 3/16" being long enough. So, he simply marked it and ground a radius on the backside of the extension receiver. Was able to stay out of the weld and gusset, so structurally it should be a non-event. You can compare the stock photo above to the photo below and see that he took about 1/4" of material off the back side.
It looks close to the end cap, but if the Jeep bangs the bar hard enough to get into the fiberglass I have bigger problems than the fiberglass.
The second picture isn't as good, but there's no contact with the end cap on either side:
I did talk to Roadmaster and they don't recommend using the extension and a hi/low. I don't have any reason to question the integrity of Cajun Camper's setup, I just know Roadmaster isn't willing to say "yeah, do that."
This will be a good rigid setup. Hopefully all this will be of help to someone else.
Gottawonder
Old 05-05-2014, 06:56 PM   #20
tmmar's Avatar
OOFA!! that is real close to the bumper!!
Looks like a nice setup though!
Tom and Margaret
2014 Berkshire 390bh-60
berkshire
