Old 04-30-2014, 01:48 PM   #1
Gottawonder's Avatar
Roadmaster Falcon A/T on my Berkshire
Got a Roadmaster Falcon A/T tow bar rigged up to pull a 2014 Jeep Wrangler Unlimited:
I like the set up and was disconnected and had the bar folded and stowed in about 2 minutes the first time I unhooked. I posted this in the Berkshire section with a couple of notes:
I'm going to have to add a 2" high/low adaptor to raise the RV Receiver height a couple inches (as sold by Roadmaster to get the towbar level). If the Jeep had a lift kit it would need 4" with this particular set up and I don't think there's room to do that without cutting into the fiberglass or doing a receiver extension THEN the 4" lift. (Hmmm...)
I have every intention of adding the M&G braking system to the Jeep at next possible moment. I like stopping when I want to. THAT said, I was not uncomfortable at all pulling the Jeep home without it. I didn't feel like the Jeep was pushing me around.
Anyway, 1 step closer!
Gottawonder
2014 Berkshire 390RB-60
Gottawonder is offline   Reply With Quote
Old 04-30-2014, 03:07 PM   #2
Sledder10's Avatar
How heavy is the Jeep? Thinking about pulling my 2006 ram 1500. Rig looks great
Sledder10 is offline   Reply With Quote
Old 04-30-2014, 05:09 PM   #3
Thanks. The Jeep is around 4,100 pounds as I recall.
Old 04-30-2014, 05:33 PM   #4
Sledder10's Avatar
Hey thanks for the reply.
Old 04-30-2014, 06:19 PM   #5
Jetjdm79's Avatar
Looks great indeed!
I just got a quote for a Blue Ox Aladdin, I believe with an Air Force 1 break controller. Haven't pulled the trigger yet.
How'd you decide on the unit you purchased! Thanks for the post!
Justin
Harrisburg, PA
2014 Berkshire 400BH-360
2014 Jeep GC Overland
Jetjdm79 is offline   Reply With Quote
Old 04-30-2014, 06:42 PM   #6
I think the tow bar is a bit low on the Berkshire. I have the blue ox aladdin set up and tow a Chevy 1500 and found I needed 3" to be level. I went with the invsibreak system and must say it is convenient not having anything to install for toad breaks once hooked up. You have a great looking rig and tow car!
CT Camper is offline   Reply With Quote
Old 04-30-2014, 06:55 PM   #7
Campin Cajun's Avatar
Don't shy away from a lift and tires. I use a 6" drop hitch turned upside down to line my tow bar up. Works perfectly.
Name:	ImageUploadedByForest River Forums1398902085.082830.jpg
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 04-30-2014, 07:09 PM   #8
Terrilegacy's Avatar
Are these jeeps stick or automatics
Terrilegacy is offline   Reply With Quote
Old 04-30-2014, 07:28 PM   #9
Mine is an automatic. I just have to put the transfer case in neutral, transmission in park. Good to go.
Old 04-30-2014, 07:33 PM   #10
Jetjdm79's Avatar
Thanks for the info!! And, I appreciate the kind words!! :-)
Justin
Harrisburg, PA
berkshire
