Old 05-14-2016, 04:29 PM   #1
DJP6371's Avatar
Roof Cleaning
Has anyone used a pressure washer on their Fibreglass roof?
I watched one of those how to videos and they were using one.
Sent from my iPhone 'cause I'm probably out in the RV!
DJP6371 is offline   Reply With Quote
Old 05-14-2016, 04:38 PM   #2
Flybob's Avatar
I would not use a pressure washer on any portion of my RV. If set up properly and used properly they are a fair solution at best. If used improperly or you slip up, you can seriously damage the caulking and seals and cause leaks. It is way too easy to make a mistake and damage something. I have witnessed a pressure washer in the wrong hands rip apart a 2X6 pressure treated board.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-14-2016, 06:32 PM   #3
dan-nickie's Avatar
The guys that wash my motorhome use one. I don't have a problem with it.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-14-2016, 07:14 PM   #4
VinceU's Avatar
I've used the 10,000 psi version for cleaning steel and tubing. Not for RV, for sure. However I use the 1,000-2,200 psi versions for auto and my RV cleaning. Can reach places cannot reach with rag or brush. Never have damaged seals or painted surfaces. Most commercial cleaners use them now.
Old 05-15-2016, 07:12 PM   #5
I've use one on my roof but only the roof. I am afraid it might do damage the paint. Jim
jrlebaron is offline   Reply With Quote
Old 05-15-2016, 08:35 PM   #6
BobbyJ
Bobbyj's Avatar
All you need is Protect-All and a microfiber cloth. Simple on the fiberglass roof.
Bobbyj is offline   Reply With Quote
Old 05-16-2016, 01:15 PM   #7
BamaBob's Avatar
X2 also the stuff sold on www.washwax.com is 'da bomb IMHO.
Put that stuff on your coach and the film makes your finish slick - even bird poop (if it sticks at all!) easily wipes off.
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 05-16-2016, 07:13 PM   #8
rsdata's Avatar
Pressure washers are not all the same... power is different and tips are different for different uses...
Use the right pressure washer with the right tip and hold the wand at an appropriate distance from the surface and you will get a better wash then just water alone.
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 05-16-2016, 08:14 PM   #9
2007 WildCat 32QBBS
05CrewDually's Avatar
Agreed.^^^^^
I run a wide fan tip and at about half throttle. Never had an issue. Also, start and stop off the piece your power washing. Gives you more control instead of a sudden burst in one spot.
05CrewDually is offline   Reply With Quote
Old 05-16-2016, 08:21 PM   #10
BandJCarm's Avatar
I'd use my little electric one.
Sidebar: I'm about to order a big tarp to go over the new TT.........no way I'm going to let it sit under trees for another 2 years like last one. Took every grandkid I had to get that stuff off, and it never did come completely off. Black streaks down side, and roof was awful.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
roo, roof
