Old 09-02-2015, 05:01 AM   #11
Does anyone have any pictures of what the so called metal plate upgrade is suppose to look like? When RF has a solution for a problem on their coaches do all owners get notified of the fix, solution ?
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 09-02-2015, 05:52 AM   #12
Fulltime in our Berkshire
KennyGolub's Avatar
I don't think so, otherwise they would have done all my slides at Goshen.
I had my rubber wiper under the kitchen slide rip in half and hung down.
At Goshen, they used jack stands to hold the slide up while they replaced the rubber wiper AND put in the metal plates for it. They did not do anything with the other three slides.
I would think the metal plates should be on all slides, or at least the kitchen slide that holds the weight of the residential fridge.
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 09-02-2015, 06:39 AM   #13
I-RV's Avatar
The wardrobe slide which operates by cables rests on plastic (probably Delrin) 5" rollers. The BH model has five rollers and other models have three. The rollers contact a soft wood bottom of the slide and since the wood gives under the slide weight, the gap between the slide and motorhome narrows. Not sure if FR corrected this problem on later models.
There are post about this which I could not put my finger on. I put the plates on myself. FR has made no recall and appear to willing supply the plates gratis, but the install will be on you unless at the factory. -Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 09-02-2015, 06:47 AM   #14
Kenny I agree and would rather on issues like this be proactive than reactive after something breaks and more damage occurs. Could you post a picture or two of the plates that were installed at Goshen by the factory ?
Joe & Lori
Old 09-02-2015, 06:54 AM   #15
Hank after installing the plates have you noticed that the slides operate like they did when you first bought your coach ? Can't imagine the plate being more than an 1/8" but there must be enough play in the height where they do not create a binding situation for lack of space on top. I'd like to ask you also if you could post a picture of your installed plates. Thanks.
Joe & Lori
Old 09-02-2015, 07:07 AM   #16
I-RV's Avatar
Joe - I believe that I also had roller installation issues, since my rubber seal went very early. I had to desperately install the plates since the bottom of my slide was rubbing on the MH's metal siding. I'll dig up pictures for you. Later - Hank
Old 09-02-2015, 07:19 AM   #17
KennyGolub's Avatar
About photos ...
I will gladly post pictures of the plates when I return home from work at 5PM, but I'm sure someone else will get them up here before then....I'll keep my eyes open and if no one does, or if their installation is different (can't imagine how), I will be sure to get the pics up here...
Ken
Ken & Laurie
2016 Chevy Colorado
Old 09-02-2015, 08:33 AM   #18
As I understand the issue as regards to needing plates. This is a issue that started because the rollers were installed improperly. They should be over a support in the slide and they are not. The way to tell if your MH has this issue is the plywood will start to have deep groves where the rollers sink in to far. The fix is simple and it seems like it is permanent. Not all need it. Keep an eye on the bottom of the slide and get the plates on before it gets to the point if ruining the seals.
Mine didn't have the issue. Yours most likely won't either but you know how to check and what to do. I believe they are very easy to install.
Old 09-02-2015, 09:15 AM   #19
Kitchen slide too??
On my 390 RB, the kitchen slide (has refrigerator in it) seems to creak and groan at lot more than when it was new. Anyone else notice THIS?
It's always been a bit scary to watch it go in and out; it tips inward and looks like it's just going to fall into the coach!
Boowho??
boowho is offline   Reply With Quote
Old 09-02-2015, 09:17 AM   #20
Mine is the same. It's scary sometimes.
slide
