Old 09-14-2015, 06:33 AM   #1
KennyGolub's Avatar
Rust in House battery compartment
I've been regularly cleaning off the corrosion on the strap buckles for the 6v batteries caused by the charging of the house batteries. What concerns me is the rust on the floor of the compartment. I see where I will need to remove the batteries (no later than next spring) and sand/paint the floor.
I'm looking for a way to neutralize the rust. I have heard that baking soda will do it. I've also heard about electronics to neutralize the ions and stop it.
Anyone here using a successful method ?
Thanks,
Ken
Ken & Laurie
Retired Cleveland CPD
2019 Entegra Aspire 44W
2018 Jeep Wrangler Unlimited
KennyGolub is offline   Reply With Quote
Old 09-14-2015, 06:40 AM   #2
Ken,
I've bought products from this company that have worked well.
Rust Paint - Rust Proofing Products - Rust Protection - Corrosion Control - Eastwood
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 09-14-2015, 06:54 AM   #3
You can also use battery pads. Check Amazon.
Old 09-14-2015, 07:02 AM   #4
ourflat's Avatar
I just cleaned mine with baking soda and will touch-up the paint with black rust-oleum.
Frank
KM4FVI
Frank
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
ourflat is offline   Reply With Quote
Old 09-14-2015, 07:15 AM   #5
KennyGolub's Avatar
I like that idea. Thanks.
Ken & Laurie
Old 09-14-2015, 07:17 AM   #6
KennyGolub's Avatar
Frank
KM4FVI
Thanks, Frank. I think I will do that to hold it over until spring. I'm hoping to retire after the first of the year and will hopefully have more time to do things like that.
Ken
Ken & Laurie
Old 09-14-2015, 07:25 AM   #7
I-RV's Avatar
Ken - Your strap buckles will eventually and you will go crazy trying to find new ones. I replaced with solid rubber bungee's. - Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 09-14-2015, 08:53 AM   #8
tmmar's Avatar
I had the same issue but I put these in the battery compartment and they neutralized all of the corrosion. They work very well. I bought several and cut them up and put them on top and on the sides of the batteries.
Battery Mat home page
Tom and Margaret
2014 Berkshire 390bh-60
Old 09-14-2015, 11:26 AM   #9
KennyGolub's Avatar
What size are they and what do they charge? I don't see a price listed on the site.
THanks,
Ken
Ken & Laurie
Old 09-14-2015, 11:48 AM   #10
accumack's Avatar
I used this stuff it worked great and it lets you know when you have gotten rid of all the acid in the compartment.
NOCO 14oz Battery Cleaner and Acid Detector - Walmart.com
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 09-14-2015, 11:52 AM   #11
dan-nickie's Avatar
Do you just spray it on and leave it, or do you have to wait and then wipe it off?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 09-14-2015, 12:02 PM   #12
accumack's Avatar
Spray it on wait a few minutes then rinsed it with water. Repeat until spray doesn't change color. I took my batteries out so they didn't get neutralized and ruined. I had a lot of corrosion and it removed it all.
Ham KG5LTL.
Old 09-14-2015, 12:03 PM   #13
KennyGolub's Avatar
What I read on the WalMart page says leave it on a few minutes then rinse it off.
I think I'll pick it up for this weekend.
Ken & Laurie
Old 09-14-2015, 12:07 PM   #14
accumack's Avatar
I saw on a car forum that someone sprayed it all over the battery and it killed the battery. I guess it neutralized the acid inside.
Ham KG5LTL.
Old 09-14-2015, 03:23 PM   #15
A32Deuce's Avatar
Hate to tell you Ken, but, You won't have more time when you retire. All of a sudden you get buzzier. I thought the same thing back in 08!
A32Deuce is offline   Reply With Quote
Old 09-14-2015, 03:28 PM   #16
accumack's Avatar
I agree I don't know how I ever got anything done while I was working because there doesn't seem to be enough time to get things done now.
Ham KG5LTL.
Old 09-14-2015, 03:43 PM   #17
tmmar's Avatar
THanks,
Ken
Ken,
Haven't bought them in a while but I believe they cost about $5 for an 8x12 piece. They really work great.
Tom and Margaret
Old 09-14-2015, 04:13 PM   #18
Just ordered 4 mats for my batteries. Checked e bay, amazon, Jegs, found them cheapest here.
Battery Store - Top Discount Batteries, Phone Batteries & More at BatteryMart.com
Under 24.00 with shipping.
Joe & Lori
Old 09-14-2015, 04:43 PM   #19
Have same problem on Berkshire going to remove house battery's and clean and under coat. Floor of compartment then line floor with 1/4 inch piece A zak
( plastic composit ) also put 1/2lip around A zak to hold battery's from moving around then get marine hard ware to hold battery's in place the metal hard ware is shot .the only problem is work keeps getting in my way of getting anything done
Blazer is offline   Reply With Quote
Old 09-15-2015, 06:00 AM   #20
KennyGolub's Avatar
Thanks to all for the replies. Lots of good ideas.
Now I can start building my project list for 2016.
Thanks Again,
Ken
Ken & Laurie
battery
