Old 09-03-2012, 12:17 AM   #1
marialee-Berkshire410qs
marialee's Avatar
Sanitizing Fresh Water Tank
How do you put the bleach into your fresh water tank to sanitize? We have a Berkshire 410Qs 2011...Thanks
marialee is offline   Reply With Quote
Old 09-03-2012, 03:09 AM   #2
billygo3251's Avatar
I attach the hose to the coach, pour the bleach I the other end then I attach it to the spigot.
billygo3251 is online now   Reply With Quote
Old 09-03-2012, 07:50 AM   #3
Herk7769's Avatar
I do similar with our 5th wheel.
1/4 cup of bleach in the end of the hose.
Stick the hose into the gravity fill port.
Run water until it is coming out the vent.
Pressurize with the pump
Open the hot water bypass valves (make sure the anode is back in)
Open the furthest tap from the pump an wait till you smell chlorine
Close and work your way back to the pump using the same for all faucets (including the outside shower!)
Don't forget to pop the screen from city water hose fitting and jiggle the check valve till chlorine smell comes out (won't take long).
HAM CALLSIGN - KC3FFW
