Old 05-09-2013, 10:19 AM   #31
Originally Posted by Himcules View Post
rg5, rg58, rg59, rg6 all differ in ohm ratings and max frequencies...
rg6 rated for 75ohm and up to 3000mhz
rg5 rated for 50ohm and up to 3000mhz
rg59 rated for 75ohm and up to 1000mhz
rg58 rated for 50ohm and up to 1000mhz
most satellite signal (dish to stb) has to be rg6 because of the 75ohm and higher frequency requirement
OK, got it...... I'd guess that the 1000mhz are pretty much obsolete, then.....
Last question then..... what would be the effect of using the wrong ohm rating.... In other words you should really have a 75 but use 50 or vice versa??
I'm still trying to figure out why my OTA High Def is so much better than my Dish Network High Def.
Thanks, Himcules
Boowho??
boowho is offline   Reply With Quote
Old 05-09-2013, 10:38 AM   #32
Himcules's Avatar
Thanks, Himcules
Boowho??
i suspect it's because of the cable you have going from stb to the tv.
like i said before, the tv has an internal tuner. that tuner is connected to the coax to the ota antennae. the tuner sends digital images to the screen internally. no other cable. the internal tuner sends 1080i or 1080p to the screen.
chances are, you have your dish connected to your stb by coax (only way to connect right now). the question is, how is your stb connected to the tv. if you are using coax, then your picture quality is poor. if you are using rca composite to the media switch box, then your picture quality is poor. if using either of these methods, you only get 480 lines per inch maximum to the screen.
only way to get hd picture quality on the tv from the stb is to use a hdmi cable or component video cable. hdmi gets you up to 1080p. component gets you 1080i iirc.
since FR released this model with new TV's that have HDMI connections but insist on using rca composite cables, our picture quality is poor. really bad implementation by FR's entertainment design person. might as well be putting an old tube tv in there since all they are transmitting is that level of picture...
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 05-09-2013, 02:21 PM   #33
For OTA :
COAX (installed by FR) from the OTA antenna directly to the TV and using the internal TV Tuner.
For the DishNet Work
COAX (again, installed by FR) directly to the set top box (Dish Receiver) from the cable connector in the power bay and then HDMI from the Dish Receiver to the TV.
That's how I'm wired. Maybe DN's Hidef signal is no where as good as they brag about??
Boowho??
Old 05-09-2013, 02:47 PM   #34
DS ADV Rider
Originally Posted by Phil57 View Post
.... and I would like a blu ray player in the MH. Most DVD we own are blu ray. I didn't know enough about it to know what can be done ....
Even though our trailer has a Jensen radio/DVD player, I take a Sony PlayStation 3 with me, set it up alongside the Sat Receiver, and connect it to the TV via HDMI. The A/V connection from the TV to the Jensen takes care of the sound, the the PS3 plays Blu-Ray AND/OR any movies downloaded/copied to it's hard drive.
I didn't get the PS3 for games - when I set up my Home Theater a couple of years back, my son said I "must get a PS3 .... as way better than a DVD player". I did, and I would agree.
Bob
Lacrosse 301RLS Touring Edition
GMC Sierra SLT 2500 4X4
BMW F650GS Dakar
Suzuki DR350SE & Suzuki DR650SE
Specialized FSR XC Comp
DualSport is offline   Reply With Quote
Old 05-09-2013, 02:53 PM   #35
Bob
Your son is GOOD!!!!! He needs to go into sales when he finishes college!!
Boowho??
Old 05-09-2013, 05:49 PM   #36
Berkshire 390QS
NO3putt's Avatar
Have a PS3 and WIIU. the PS3 plays movies great and have HDMI cable hooked directly to TV.
NO3putt is online now   Reply With Quote
Old 05-09-2013, 07:57 PM   #37
Himcules's Avatar
For OTA :
Boowho??
you are set up the optimal way. can you check your stb's display settings? it should be set to the highest setting since you are on hdmi to the tv.
Old 05-09-2013, 07:59 PM   #38
Himcules's Avatar
Bob
i used to do the same. i keep the ps3 at home now. i got a sony blueray player that has usb plugs and connect my usb disk drive that has movies on it. the sony blueray player has a similar interface to the ps3 and plays great movies from disk. it also has an hdmi output.
the ps3 is way more machine than i need for travel tv... it's larger and the fan runs louder and needs to be air cooled correctly. the blueray player is 1/4 the size and nearly the same video capability...
