Old 04-27-2014, 03:55 PM   #11
gasman94's Avatar
Originally Posted by EJM4 View Post
I have a traveler on my 2014. Lazydays installed it when I purchased the coach.
Which receiver are you using? Did they have to modify anything?
gasman94 is offline   Reply With Quote
Old 04-27-2014, 03:57 PM   #12
gasman94's Avatar
I also have a '14. No area marked on roof.
Old 04-27-2014, 04:08 PM   #13
tmmar's Avatar
Gasman,
Don't know what to say. I was on my roof the other day to look at the front AC and was surprised to see a circle drawn with what looked a black marker. I am assuming (I know what happens when you assume) that it is the location to drill for the wiring if you wanted to install a satellite receiver.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 04-27-2014, 04:20 PM   #14
JTN8's Avatar
I also have the travler mounted on the roof of my 2014 berkshire. Had it installed when I purchased it. No mods had to be done.
Old 04-27-2014, 09:01 PM   #15
silver's Avatar
Satellite wiring Location
Originally Posted by gasman94 View Post
Well, went to Camping World yesterday for an install of a winegard travlr dish. I guess there is no opening on the roof of "14" Berks, so they were unable to put in the dish without major modifications. Anyone need a dish hopper and some joeys?
This was posted some time back. I do not know if it is accurate. May help. Good luck.
silver is offline   Reply With Quote
Old 04-28-2014, 06:07 AM   #16
EJM4's Avatar
Direct TV, not sure of the exact model. LazyDays installed the dish on the center of the roof and the wired came down and into the center entertainment area.
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 04-28-2014, 06:37 AM   #17
gasman94's Avatar
Looking at the floor plans, (I have a 390FL), the problem may be that my front TV is in the slide. That is what the guy at CW commented on..no way to wire into the slide without major (read expensive) wiring/modifications.
Old 04-28-2014, 10:44 AM   #18
Gasman do you have a cable labeled Sat feed in your entertainment center? The only use for that is the other end is on the roof. If you have that (and it's a switch plate with the cable fitting on it) then you should have the prep in the roof.
Old 04-28-2014, 11:40 AM   #19
gasman94's Avatar
I believe that I do, but I'll check it next time I'm at the storage area.
Rich
Old 04-28-2014, 07:26 PM   #20
That's EXACTLY where I found mine on the 2011 model. However, I found no power wiring; had to improvise.
Boowho??
P.S. Love the professionalism of the drawing itself.....Sorta like it was drawn on a paper napkin or some such!!! That drawing came DIRECTLY from FR!!! Guess they don't have a CAD/CAM department, eh??
Boowho??
boowho is offline   Reply With Quote
satellite
