Old 09-07-2015, 12:03 PM   #21
Left Coast
Have a King Flex, will work with all providers, is portable....bought a receiver to stay in trailer, pay 6. per month....receive local channels 250 miles away....used it coast to coast, also supports 2 receivers...(lets see...cooking shows or football). For 2nd tv, I take a box from home.
Old 09-07-2015, 12:43 PM   #22
Originally Posted by mtnlvr View Post
I like the Dish Trav'ler. The basic crank up antenna that came with my Solera is useless outside of a large city and I'm usually not traveling in the city. Spending the extra money for the roof mount was well worth it for me. After a long day of driving and then setting up in my space, I'm tired and don't want the hassle of setting up a tripod, compasses locating the satellite & locking it to prevent theft. I researched the various systems and felt this was the best & easiest way to go.
If you can afford it, the Trav'ler is the best there is, IMHO. Less rain fade and 3 LNBs make it THE hands down favorite, for me.
Boowho??
boowho is offline   Reply With Quote
Old 09-07-2015, 12:45 PM   #23
Left Coast
Ant. depends on which provider you have.
Old 09-11-2015, 08:18 AM   #24
If you can have the dish mounted on the roof try to have it mounted on the frount. Usually there are no trees in the front making it easier to receive a signal. I'm not sure but I think dome dishes are not available for HD it's something to check out. Jim
jrlebaron is offline   Reply With Quote
Old 09-12-2015, 09:10 AM   #25
I have the Wineguard Trav'ler mounted to get Directv in HD. I wanted HD. If you don't care if it's HD or SD then go with the a cheaper roof mounted model. As far as programming, I'm a sports nut so nothing comes close to Direct and the amount of HD channels that feed that itch. I take my DVR from the house with us when we go, so I don't pay for an extra receiver. If I want local news or weather, I'll use the internet or connect to cable if the park offers it. You mentioned NASCAR, with some races now on NBC-SN, make sure you check the other providers to make sure you get that one. You need the Dish's "Top 200" to get it. Since 2 of my TV's are disabled or un-viewable going down the road, I didn't need the 'in motion" dish. Make a list of your 'must haves or wants' and go from there. I like to push a button and the dish does the work and I get to watch what I'm used to.
JJvike is offline   Reply With Quote
Old 09-12-2015, 09:17 AM   #26
Oh, and my antenna is mounted in the middle of the coach. My cable was in the middle but I've seen on here where some have the pre-run cable up front. Call Randy at FR and let him tell you where that cable is so they cut the hole in the right place.
Old 09-12-2015, 10:52 AM   #27
edgewant's Avatar
I have the Winegard Traveler for Dish HD. It does a great job as long as its sight path is unobstructed. Since we like Corp of Engineer campgrounds we often have difficulty getting all 3 satellites. As an "insurance policy" I recently purchased a King VQ4500 Tailgater portable dish. I use the existing cable hook-up in the power bay. I also installed a power pass splitter (one leg passes power) to split between cable and satellite and an AB switch to switch between the roof dish and the portable. I did some signal attenuation so I purchased a non-powered in-line signal amplifier. The set-up works great. Haven't really had a need to use the portable yet but have checked it out at home and while the signal level on satellite 129 isn't great it is good enough.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 09-12-2015, 11:09 AM   #28
I have not RVed in about 10 years, but back then I would pull my direct receiver (box) out of my home entertainment system and put it in my trailer. The only thing I need was to purchase a small portable dish and tripod. I would also have a 100-200 ft of coax on a reel so I could place my dish/tripod in the best area for a clear line of sight to the sky.
earlbalentine is offline   Reply With Quote
Old 09-12-2015, 01:12 PM   #29
nathantoensing's Avatar
With DirecTV simply call customer service and give them your temporary "Service" address. There's a Billing address and a service address. Everywhere we've gone I call with the new service address then we get all the local channels immediately!
--Nathan
2016 38a
--Nathan
2016 38a
nathantoensing is offline   Reply With Quote
Old 09-12-2015, 02:23 PM   #30
I don't understand the address location or zip. I didn't have to change anything on the home receiver when I was RVing. Just plug it in and it was like I was at home.
I know you can go in and change your zip code if you want, because I did that at home.
I would enter a east coast zip code that way I would receive all channels 3 hrs earlier.
So instead of waiting to watch prime time TV at 7 I could watch it at 4:00pm.
satellite
