Old 06-11-2011, 09:16 AM   #1
Satellite signal on outside TV
Just put in an outside TV and am only able to get local channels. The TV will not display the programming that I am watching on the living area TV. What am I doing wrong? Thanks
BamaCorner is offline   Reply With Quote
Old 06-11-2011, 09:29 AM   #2
tmmar's Avatar
Just a quick thought- do you have the outside TV on the correct input?
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-11-2011, 10:08 AM   #3
Tried every input and .......
received a "no signal" notice on all of them.
Old 06-11-2011, 12:36 PM   #4
Herk7769's Avatar
How are you watching your satellite on the L/R TV?
How do you expect the signal to get from the SAT receiver to any other TV?
HAM CALLSIGN - KC3FFW
Old 06-11-2011, 01:05 PM   #5
I have a box that the signal goes through.....
and passes to the other televisions. I already get that signal to the bedroomm tv. Same was true of the Alegro Bay that I had before I purchased the Birkshire. Don't know why the signal is not going to the outside television.
Old 06-11-2011, 03:36 PM   #6
Herk7769's Avatar
Jim,
What I meant was are you using a coax out of the satelite receiver and then splitting it or is the connection directly to your TV?
Old 06-11-2011, 05:30 PM   #7
Should be split since I am getting..
satellite in the bedroom. However, I push the third tv button and still just local channels.
Old 06-11-2011, 05:39 PM   #8
Herk7769's Avatar
Sorry, but I am totally unfamiliar with your coach's AV system.
I thought I could be of help; but no such luck...
Old 06-12-2011, 07:04 AM   #9
I only had a few minutes to ........
work on it and had hoped that I might get some tips before I went back. I'm sure I'll find the problem when I go back to mount the television next week. Thanks anyway!
Old 06-13-2011, 11:44 AM   #10
Berkshire 390QS
NO3putt's Avatar
Got mine to work, use the red/white/yellow cables from the direct TV box into the switch box, then also connected the direct TV coax cable to the common feed in the motor home. I also don't understand why the switch box is not able to do this and when i get some time will look into why. My Bedroom TV works fine with the swithc box like it should. Wish Forest River would provide a better wiring diagram to begin with
