Old 05-29-2015, 05:08 PM   #11
Campin Cajun's Avatar
It's also a good idea to let the generator run for a few minutes before putting a load on it. This allows any dampness to dry up before the load is applied. And also allows the gen to warm up.
This step isn't written in any book or manual. I live in the south in very humid conditions and it's the way I've been taught when bringing any genset online.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 05-29-2015, 05:31 PM   #12
Great advice. I've had mine stall out by putting a load in it before it's warmed up. It restarts with a big puff of black smoke. It can't be good for it. I learned to wait.
Old 05-29-2015, 05:42 PM   #13
tnbendr's Avatar
I did consciously wait (either common sense or dumb luck) before turning the AC's on.
Ben & Michelle
2015 Berkshire 38A
2005 Jeep Wrangler toad
tnbendr is offline   Reply With Quote
Old 05-30-2015, 07:42 AM   #14
I-RV's Avatar
tnbendr If your shore line has enough amperage to run your AC's, then why start the generator. If your shoreline is insufficient, then it makes sense to start the generator. But once the generator is running, everything will be on the generator. The shoreline will be not used. X2 to the suggestions of shedding the load when the generator is started.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 05-30-2015, 11:55 AM   #15
dan-nickie's Avatar
I believe he said because he wants to exercise his generator while parked.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-30-2015, 12:37 PM   #16
ernest917's Avatar
I always turn off AC then UNPLUG, start gen and wait for the " beep " then fire up AC 's.... Rather be safe than sorry ... Have had multiple techs tell me that's the safest way....
ernest917 is offline   Reply With Quote
Old 05-30-2015, 01:00 PM   #17
dan-nickie's Avatar
Actually sometimes on hot days when I'm leaving a campground, I will start the generator with the air conditioner on. Everything keeps right on working when I unplug the power cord and I pull out of the campground with a cool coach. I know some of you are going to say its bad, but I do it anyway at my own risk.
Dan
Old 05-30-2015, 03:02 PM   #18
Dan I do the same thing. I never knew it was a bad thing to do. I know not to hit either side with a load but it never occurred to me that this would harm the transfer switch.
Old 05-30-2015, 03:27 PM   #19
tnbendr's Avatar
I am only plugged into a 15 amp 110 circuit, so I don't even want to try the AC. I wanted to run the AC and exercise the gen, especially now that I've learned it "needs" to run. It was a little dirty on the exhaust for awhile at first but I ran it for about 2 1/2 hrs...it's clean now!
Ben & Michelle
2015 Berkshire 38A
Old 05-30-2015, 07:16 PM   #20
15berkxl's Avatar
The transfer switch is designed to disconnect the shore power and connect to generator power without causing harm. There is a break in power seconds in duration that no power is sent to anything in the coach. Otherwise the coach would attempt to sync with the local utility company and that would not go well. The a/c compressor will turn off during the transfer and by design will not restart for 5 minutes max. This prevents power surges to the a/c units and generator.
Wayne
15berkxl is offline   Reply With Quote
vent
