Old 05-29-2013, 10:21 AM   #1
RKC02's Avatar
Seriously Considering a 2014 Berkshire 390RB-60
Hello All! I am not an owner (yet) but DW and I are seriously looking at a beautiful 2014 390RB-60 and will hopefully be new owners soon.
As such I would like to ask any advice from experienced owners on what options and/or required accessories I should get with a new Berkshire. The one I am looking at does not have the slide tray, but I don't know if that is a simple convenience or a necessity. I will have a surge protector hard-wired in and have already confirmed that the wheel alignment will be checked. Not sure about satellite TV (don't have it yet but may switch from cable soon). If we do switch, is it better to have dealer install the sat antenna or is it just as easy later?
Any other specific recommendations or things to look for?
Many, many questions as we get down to the wire and any advice would be greatly appreciated.
RKC02 is offline   Reply With Quote
Old 05-29-2013, 10:30 AM   #2
By all means, get the slide trays in the basement. I could not live without them. I have two but want to add the third one. I'm AM full timer, BTW.
Make sure they are NOT Ez-Glide. I have one and it is junk. Mor-Ryde is far superior.
I can slide a loaded Mor-ryde out with one finger. I have to tug like hell on an empty EZ-Glide. I'll be replacing the one EZ-Glide with a Mor-Ryde tray as $$$ permit.
Boowho??
boowho is offline   Reply With Quote
Old 05-29-2013, 10:36 AM   #3
tmmar's Avatar
RK-
Welcome to the forums. I'm sure that you will be very happy with your Berkshire.
I would make sure to get air conditioners that are 15000 btu heat pumps. These will cool the coach better in the summer heat and help heat the coach in cool weather. I believe it comes with 13.5 btu air conditioners as standard.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 05-29-2013, 10:43 AM   #4
JTN8's Avatar
I agree with the A/C's, I just ordered a 2014 390BH and have forest river installing two 15K's. they will only put the heat pump up front though, not sure why. I also have my dealer adding the winegard traveler satellite dish on mine since I have direct tv. Can't wait to get mine!!!!
Old 05-29-2013, 11:37 AM   #5
Berkshire 390QS
NO3putt's Avatar
Pro and Cons on roof mounted dish. Roof mounted there may be times, may not be often that trees will block the dish. Cost for roof mounted dish? Ours works great 95% of time unless there is trees.
Tailgater (dish network) portable dish works good also to put outside for the 5% of the time trees are in the way.
Our unit came with roof mounted and then we puchased a tailgater later to cover the few times the roof dish is blocked.
As for the basement slides, we don't have any, we just get out what we need before opening the slides. Even have our full size bikes in the basement storage.
Old 05-29-2013, 11:43 AM   #6
RKC02's Avatar
New Berkshire
Thanks for the quick replies and information!!
Regarding the air conditioners - larger units makes sense but I can imagine a hard-sell at the dealership. This is an in-stock unit, not an order. I'll certainly ask about it but can hear the crying already......
Old 05-29-2013, 11:47 AM   #7
JTN8's Avatar
It's actually a pretty easy swap and mine only added $500 to the price of my ordered coach. You'd be surprised what a dealer would do to make a sale..... You can actually get quite a bit of stuff thrown in for the right deal. Good luck with the purchase!
Old 05-29-2013, 11:53 AM   #8
Berkshire 390QS
NO3putt's Avatar
We purchased ours "in stock" so ordering anything from FR was not a option, however since we purchased an 2009 in 2010 the dealer wanted it gone. He installed the satellite antenna and washer/dryer combo as a bonus. Would really look at the cost they may charge you for the roof mounted satellite antenna vs. Getting a portable one like tailgater ($350) plus reciever ($150).
Old 05-29-2013, 01:00 PM   #9
Himcules's Avatar
agreed to all that was said above. also get them to add on the maxxair ii vents above the midcoach and bathroom vents. simple and only ~$100 in parts + 15mins labor each. imo, they should throw it in free if you ask for it.
i also have the EZ-Slide and do not like it...
if you are ordering, get the 275 tires vs the 255 size. you get more load capacity that way. otherwise just change to those tire sizes after you wear out the original set.
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 05-29-2013, 01:12 PM   #10
JTN8's Avatar
Actually found out from FR that all the 2014 chassis (340 hp) from freight liner come with the bigger tires, upgraded front axle and larger airbags that put the GVWR up to 32000 or 33000 lbs. still limited to 33000 gross combined due to the tranny... Called to find put what ,one was going to have....
