Old 07-03-2016, 11:36 PM   #31
MotoxDad's Avatar
When should you change the fuel water separator?
John
2014 Berkshire 400BH
Motocross Dad
MotoxDad is offline   Reply With Quote
Old 07-03-2016, 11:51 PM   #32
klucas's Avatar
I change mine yearly during oil and fuel filter change.
klucas is online now   Reply With Quote
Old 07-04-2016, 01:28 AM   #33
NV245's Avatar
Originally Posted by dave-g View Post
so some thoughts from a hvac guy- Have your ac charge checked- its very important- The air conditioner compressor has oil in it. That oil will travel through the system and return with the Freon, but if you system is low on charge, there is not enough velocity / volume of Freon to bring the oil back to the compressor. The the compressor runs out of oil and you know what happens next.
The problem is not the compressor, it is the a/c compressor pulley bearing failing. When the pulley bearing fails, heat is created at the compressor hub and overheats the compressor shaft seals, causing refrigerant loss.
NV245 is offline   Reply With Quote
Old 07-05-2016, 05:35 PM   #34
15berkxl's Avatar
BTW according to sources at Cummin's for part number 5264021 belt there are 736 of them at the Memphis Distribution Center in case you want a few.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 07-06-2016, 05:10 AM   #35
If its the pulley bearing- I wonder it it would be best to replace it as a maintenance item. - or maybe its not that common- just you hear about every one because of the mess it makes.
dave-g is offline   Reply With Quote
Old 07-06-2016, 05:20 AM   #36
BamaBob's Avatar
Originally Posted by Bunci View Post
I went through the Camp Freightliner class recently and the three must have spare parts are, the serpentine belt, fuel filter and fuel water separator. The facilitator recommended sealing the again I a vacuum sealed bag like "Food Saver".
Which Camp Freightliner class were you in?! (We were in the 5-6 JUN Class)
And X2 Michael was adamant on those spare parts. Still not sure how I can vacuum-seal a serpentine belt (I am thinking of one of those under bed vacuum-sealed blanket bags) but the food saver not only seals meats for the freezer but fuel filters/water separators as well
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 07-06-2016, 01:10 PM   #37
Himcules's Avatar
guess i gotta get a couple of belts now too...
my 2013 with 11,500 miles just started to squeak...
anyone got an online source they bought from?
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 07-06-2016, 04:03 PM   #38
15berkxl's Avatar
Bob our food saver comes with rolls of bag material to make any size bags.
Wayne
Wayne
Old 07-06-2016, 08:40 PM   #39
BamaBob's Avatar
Wayne
Well same here Wayne but I can only imagine the size we will need for a serpentine!!!
Old 07-06-2016, 09:08 PM   #40
Phil57's Avatar
Gentlemen there is no way that damn belt needs to be shrink wrap in anything. What a friging wives tail.
Phil and Dianna
2011 Berkshire 390 RB
