Old 07-06-2016, 08:16 PM   #41
Kenny kustom's Avatar
Originally Posted by Phil57 View Post
Gentlemen there is no way that damn belt needs to be shrink wrap in anything. What a friging wives tail.
Agreed.
I was searching high and low for an odd ball belt.. Had to be a gator back.
Found one online, got it here and the cardboard sleeve was so faded, could hardly tell what it was.
Sat in the sun for a long time.
Threw it on the crate engine. Perfect for years.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 07-06-2016, 08:17 PM   #42
15berkxl's Avatar
Phil I thought FL said to put it in vacuum bag to prevent dry rot
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 07-06-2016, 08:20 PM   #43
Changing it out every couple years will prevent dry rot.
2016 Sabre 36QBOK
Old 07-06-2016, 09:58 PM   #44
Himcules's Avatar
2016 Sabre 36QBOK
exactly! it's just another item on the regular maintenance schedule.
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 07-07-2016, 11:53 AM   #45
You could set that belt on a shelf in a back room and come back 20 years later and it will not be dry rotten. Air will not break it down. Heat and the heat from rotation will break it down.
Old 07-07-2016, 04:17 PM   #46
I-RV's Avatar
That is where mine is setting
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 07-07-2016, 04:41 PM   #47
Originally Posted by BamaBob View Post
Well same here Wayne but I can only imagine the size we will need for a serpentine!!!
If you know how, you can flip fold a belt to 1/3 its length. Do it all time for band saw blades.
This is an 81" long blade full length and then folded to 1/3. Longer blades can be folded again and made to go down to 1/6th.
ID:	113390   Click image for larger version
Old 07-07-2016, 04:51 PM   #48
15berkxl's Avatar
Phil so you are saying the information reported in this thread by people who attended the FL camp is not true? If that's the case I rely on others with supposed knowledge to enlighten me in areas I need help with. If the info is bogus why do I waste my time?
Wayne
Wayne
Old 07-07-2016, 06:05 PM   #49
Serpentine belt
Wayne if I'm wasting your time move on. I have my opinion as did Mike at CFL. I disagreed when I sat in his class and I disagree now. I have a belt that has sat in my rear compartment since April of 2016 and it's as new as when I bought it. How is setting in a shelf out of the sunlight going to break down a rubber belt meant to take countless hours of heat and friction.
I spent a few minutes searching for shelf life. Most say store it out of the sun. Someone said 5-10 years. Non of the manufacturers had any recommendations for shelf life.
Old 07-07-2016, 06:25 PM   #50
15berkxl's Avatar
Wayne if I'm wasting your time move on. I have my opinion as did Mike at CFL. I disagreed when I sat in his class and I disagree now. I have a belt that has sat in my rear compartment since April of 2016 and it's as new as when I bought it. How is setting in a shelf out of the sunlight going to break down a rubber belt meant to take countless hours of heat and friction. Do what you want and sorry for wasting your time.
Phil my reply was not directed at you but at others that post suggestions. I have never attended camp so I have to rely on those who have. I have had belts in my trunk that have showed cracks without been installed. Maybe it was from heat in the trunk. Getting to the belt on the Berk is not easy as you know with a radiator in the way the only access is from under the coach and you've seen me I'm not tiny so not an easy task.
Thanks for your insight.
Wayne
Wayne
Old 07-07-2016, 06:35 PM   #51
Wayne I'm sorry my reply was so rude and harsh. I did edit it as I thought about it. The thing is Camp FL is a good class Mike is a talker and I'm grateful for the ton of great info I got. Some of what he said is just him talking. One was the belt thing. Nothing wrong with storing the belt in a sealed bag but totally unnecessary. Unless the belt needs to be protected from dangerous fumes or subjected to fuel or oils it is not going to be damaged. Again I'm sorry for my snotty response. I can be a ass sometimes. Don't ask my wife as she will say I'm a ass most of the time. Be well see you in Goshen.
Old 07-07-2016, 06:47 PM   #52
15berkxl's Avatar
I like Diana so I won't ask her lol but I like you too. I guess I won't be at Goshen since I never heard from Frog Bob but learned today they had or have server issues. I may try a walk in at one day even if I don't camp. Think I'll go to Merritt Speedway
Wayne
Wayne
Old 07-07-2016, 08:54 PM   #53
BamaBob's Avatar
Correct Wayne,
If you Vaccume seal it will last for a few years - the reason for having a spare was for the Alaska group. Folks staying the the lower 48 do not need to do this - sorry for the confusion folks
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 07-10-2016, 07:08 AM   #54
Actually Mike Cody recommended the spare parts for everybody who owns a Freightliner Custom Chassis with Cummins engines. Nothing specifically noted about any Alaska group that I remember. He recommended the vacuum seal to preserve the integrity of the belt from spills, edge damage and dry rot. It was a recommendation not a requirement.
Bunci is offline   Reply With Quote
Old 07-11-2016, 01:42 PM   #55
BamaBob's Avatar
Good Point Bunci - thanks for the clarification!
