Old 12-16-2015, 03:55 PM   #11
JTN8's Avatar
Originally Posted by Lloydg View Post
Is that awning made by Carefree? We have a Carefree awning on our 5th wheel and purchased a shade from the manufacturer to preclude any interface issues. We like it very much and is easy to install and remove. Wish I had a picture but just thought I'd comment.
The awning on the coach is made by carefree. The vista shade is made by shade pro
Jason
Old 12-16-2015, 05:06 PM   #12
Campin Cajun's Avatar
You guys that have these should get some awning poles....hahahaha
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 12-16-2015, 06:37 PM   #13
dan-nickie's Avatar
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 12-16-2015, 09:41 PM   #14
DJP6371's Avatar
How does this Shade Pro attach to the original awning? And with the awning extended, I'm guessing you need a ladder to reach it to attach the awning?
DJP6371 is offline   Reply With Quote
Old 12-16-2015, 09:54 PM   #15
gasman94's Avatar
[QUOTE=DJP6371;1058381]How does this Shade Pro attach to the original awning? And with the awning extended, I'm guessing you need a ladder to reach it to attach the awning?[/QUOTE
Attaches in awning channel. With awning extended, you can reach without ladder to attache lower portion and I am only 5'7"
Rich
gasman94 is offline   Reply With Quote
Old 12-17-2015, 05:47 AM   #16
dan-nickie's Avatar
The bottom 6 Ft. unzips to remove and store.
The top part of the shade rolls up with the awning.
Very easy.
The initial installation was tough for me. Had to have a helper and 2 ladders.
It does slide in a groove on the shade roller, but has to be lined up with a slot on the front end cap which is not at the bottom.
Dan
Old 12-17-2015, 08:25 AM   #17
gasman94's Avatar
Very easy.
I had to remove cap toward rear to do install.
Rich
Old 12-17-2015, 08:39 AM   #18
Post's # 16 and 17 bring assembly at the Awning at the MFG.to be odd! Some Slots are at the Bottom,some other locations,some End caps are on the wrong end with NO slot for add on's! This is not just a Berk Issue,but all Divisions! Youroo!!
Old 12-17-2015, 09:38 AM   #19
A32Deuce's Avatar
Die grinder and you have an opening to get into slot.
A32Deuce is offline   Reply With Quote
Old 12-17-2015, 03:03 PM   #20
dan-nickie's Avatar
Rich
Rich, here is a picture of the slot I was talking about to get the awning through.
You can see why it was so hard.
Your way was probably easier.
Dan
