Old 10-17-2015, 11:10 PM   #11
Originally Posted by jmgllt View Post
In reference to this topic what engine and year couch is this problem associated with?
Not sure, but seems to be 2011 and earlier right now. May be newer too, but I don't know one way or the other.
Boowho??
boowho is offline   Reply With Quote
Old 10-17-2015, 11:12 PM   #12
Originally Posted by rockfordroo View Post
Electric fan will probably improve you mileage a bit. That's why almost no cars use engine-driven fans anymore.
Electric fans may not be the best for towing. They apparently they do not move nearly the volume of air that the stock fan moves. Like maybe half at best??
Boowho??
Old 10-17-2015, 11:44 PM   #13
jmgllt's Avatar
How do I know if my engine is effected by this, I have a 2012 340?
jmgllt is offline   Reply With Quote
Old 10-18-2015, 06:49 AM   #14
Originally Posted by boowho View Post
Do you know the price of JUST the 5-bolt hub (no labor).
Boowho??
Price was $960CAD so prob around $700US. I have the correct part numbers for the bracket/hub and bolts and washers as well, along with the Service Solution information from Freightliner. When I am back in my office on Monday I'll post the info.
It should also be noted that this job can be done WITHOUT removing the radiator. I have heard of some people being told by shops that it has to come out, and of course much more money to do so.
Also a good idea that while you are in there to replace the engine thermostat.
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
Old 10-18-2015, 07:02 AM   #15
You could call Freightliner Custom Chassis (don't have the number handy) and give them your VIN number. They can tell you. Or you can crawl up beside the exhaust system and with a inspection mirror count the bolts on the bracket.
James
Old 10-18-2015, 07:17 AM   #16
Yeah not sure that I'd fit up there, but I was thinking possibly with a mirror or I have a Dewalt Inspection camera that should get it.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-18-2015, 07:30 AM   #17
I-RV's Avatar
I do not understand how they might change an existing 4-bolt to 5-bolt. Seems like they have to drill and tap four locations or add one location to the four already there.
I haven't checked yet, but I was wondering whether Access Freightliner shows what you have. When I go into this site, it gives me the parts for my serial number chassis. However, the fan mount may be a Cummins item and therefore not included.
For Access Freightliner, you need to sign up for it at....
www.AccessFreightliner.com
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 10-18-2015, 07:44 AM   #18
15berkxl's Avatar
Boo I totally understand your concern but if you remove even one bolt and bolt should break you not only cause yourself a major repair to extract the remaining bolt but now FL has no liability to repair the clutch should it be defective.
Should a class action suit or recall be filed you could excluded from it.
If FL has denied that your engine is a potential make them put it in writing easiest way is to put it in writing and make them reply in writing.
Another way is to file a complaint with the NTSB or FCC then they have to respond.
I just don't want you and others getting burned if this is more than just an isolated case or if FL corrected the possibility of bolts happening.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 10-18-2015, 08:02 AM   #19
I-RV's Avatar
I agree with you Wayne. Be careful there, Boo!
Old 10-18-2015, 08:09 AM   #20
I-RV's Avatar
I did go into AccessFreightliner for my coach. Under "Engine Cooling Radiator", there is an assembly called "Fan-Engine". Unfortunately, when I go to open that part, there is a not that states that no graphic is available. It gives me a Parts List No. 263-C00200 and a Part Number of 681 000 05 N1.
I was also led to a Cummins web site, for which I haven't signed up for. It is at..
https://qsol2.cummins.com/cola2/logi...esn%3d73199415
Wow, what a URL !!! Hank
fan
