Old 10-19-2015, 07:34 AM   #41
Originally Posted by tmmar View Post
Boo,
As far as I know, it is the bolts that hold the fan to the engine block. That is why there was a concern about the need to drill and tap a 5th hole on the block.
I am confused as to how a fan would work bolted to the engine block rather than to a water pump hub.
Old 10-19-2015, 10:54 AM   #42
Name:	ImageUploadedByForest River Forums1445269977.291815.jpg
Old 10-19-2015, 11:30 AM   #43
Boo,
Phil, if (as Tom's reply indicates) the bolts in question are the ones holding the hub to the block, then a routine visual inspection may not be possible. In the pics posted so far, I don't see them.
Old Coot, I'm with you. There has to be a water pump in there somewhere.
Boowho?? (the old dog on a bone)
boowho is offline   Reply With Quote
Old 10-19-2015, 04:23 PM   #44
The plot thickens
Just sent this off to FCCC customer service. Awaiting reply.
Please advise whether or not the issue address by Technical Service Bulletin SF-388A-F has been addressed with a permanent fix on my chassis (VIN XXXXXX).
There are many reports on the Internet of problems being reported (and recalls being issued) on some Horton hubs.
These reports have also referenced other manufactures e.g. Peterbilt and Kenworth.
I would like some assurance by FCCC (preferably in a paper letter signed by a senior CS manager (or vice president) that my chassis is not affected by this issue.
Also on the Internet are (in some motor home owners forums) messages from owners in which the Horton hub or it's attachment failed causing major catastrophic damage. Repair costs have been stated to be as high as $7,000.
Obviously, this is something I would want to avoid.
Please respond ASAP.
Boowho??
Old 10-19-2015, 05:53 PM   #45
Boo,
To clarify for all.....there is a machined bracket that has the pulley for the serpentine belt pressed on to it. This bolts to the engine block and it is this unit that is the problem area. It is NOT the bolts that hold the shaft for the clutch fan that are visible in the picture above. The pulley that is shown above is attached to a bracket that is fastened to the block by 4 bolts. This is the problem area. Bolts either back out from vibration and then shear, or shear from the torque placed on it or in my case one bolt sheared and then the entire bracket broke in half (cracked). The upgraded bracket uses a 5th hole that is already in the block that is being utilized to hold a bracket for the wiring harness. It is the identical size and length to the others. The dealer just relocates the wiring support (tie wraps it to something else). There is also part numbers for the bolts and washers to be used as well.
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
Old 10-19-2015, 05:57 PM   #46
Well that clarifies things. I thought it was the 4 bolts on the hub itself. Thanks for that info.
Old 10-20-2015, 11:23 AM   #47
These are two responses to my two emails to FCCC about the fan bolt issue.
One message states that my hub is furnished by Cummins. Yet, SOMETHING in that area is plainly market HORTON. Maybe Horton supplied only the clutch??
OK so what do you all think?
Boowho??
------------------ Response One ------------------------------------
Bill,
If there are ever any recalls, we here at Freightliner Custom chassis would
issue a recall notice and you would have been sent one to your address.
There are no recalls on your unit. Please see attached
Sincerely,
David York
FCCC Representative
(See attached file: CDA Recall Letter.doc.zip)
------------------ Response Two ----------------------------------
Dear Bill,
I see that David York has already provided you a "No Recall" letter and I
wanted to expand on your questions and the previous replies you have
received from Rhonda.
1. Your unit was NOT built with a Freightliner installed fan hub, and thus
is NOT the style of fan hub that you have been reading about on the
Internet or talking to friends about, in regards to going from a 4-bolt to
a 5-bolt set-up. Your unit has a Cummins fan hub, that FCCC installed the
fan clutch to, and ultimately installed the fan to this fan clutch.
2. There are NO known issues with YOUR fan set-up in regards to what you
are describing with the 4-bolt versus a 5-bolt set-up. This is NOT to say
that FCCC is guaranteeing you that you will never have a fan, or a fan
clutch, or a Cummins fan hub failure in the future, but only stating there
is NOT a known issue with your unit that will be addressed by FCCC outside
of your normal FCCC warranty period that has expired as of 8/1/14.
3. You can certainly retain this e-mail for your records, as to what FCCC's
stance is concerning the fan set-up on your unit, BA7897.
Sincerely,
John Michaels Sr
FCCC Senior Service/Parts Representative
Old 10-20-2015, 11:44 AM   #48
15berkxl's Avatar
Who's Bill lol ok so you have one piece of the puzzle although in those emails are they saying they have had issues with clutches when installed by FLCC? But I guess that is secondary to your question.
Now I would send a similar email to Cummin's giving them the serial number of your engine and see what they say.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 10-20-2015, 12:16 PM   #49
I-RV's Avatar
Boo - This section of the reply to you from Michaels has several clues,,,
To me it says:
a) Your unit has a Cummins Fan Hub, installed by FL and is not the one involved with the 4 vs 5 bolt controversy.
b) Your unit was NOT built with a Freightliner installed fan hub Okay, you are clear Boo, but this indicates that the FL hubs may have problems and this brings up what the rest of us have -LOL
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 10-20-2015, 12:33 PM   #50
15berkxl's Avatar
I don't disagree with Hank except now the rest of us have to worry about what we have thanks Hank.
I still would send an email to Cummin's just to close that part out.
Wayne
Wayne
fan
