Old 10-20-2015, 06:23 PM   #61
Originally Posted by boowho View Post
OK, mine is BA7897 How did we determine that we were 6 numbers difference? I can't remember, but thought we figured that out a coupla years ago.
Boowho??
Was that the night you were both 3 sheets to the wind ?
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-20-2015, 06:50 PM   #62
I have no idea how we got that idea. Maybe we figured out the build date for the MH. What month was yours made.
Old 10-20-2015, 07:44 PM   #63
Actually, I think it was comparing the FR VIN, not the FL VIN.
My FR VIN last 7 are Z050680
Boowho??
boowho is offline   Reply With Quote
Old 10-20-2015, 08:09 PM   #64
accumack's Avatar
Mine is Z050632 so we are 48 apart on FR VIN mine being older. But the chassis is only 4 apart so for the clutch fan issue we should be the same.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 10-20-2015, 08:33 PM   #65
Agreed. I'd be HIGHLY surprised if you're not OK.
I've pestered them enough already, but maybe someone else could ask FL the cutoff point at which the old hub was gotten rid of and the new one put into production. Should be a simple VIN range for each type of hub.
Boowho??
Old 10-20-2015, 08:37 PM   #66
I can't find a FR vin number. My coach was made in February 2011.
Old 10-20-2015, 09:48 PM   #67
It's on the yellow sticker on the entry screen door.
boowho??
Old 10-21-2015, 07:31 AM   #68
For those interested here is the Service Solution Document from Freightliner. The updated 5 bolt part number is HOR 992092. There are also part numbers for the bolts (capscrews) and washers (not that you need these specific washers).
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
Old 10-21-2015, 07:58 AM   #69
Sheared Fan Hub Bolts revisited
boowho??
Not so in my case. 2014 390 BH-60. The VIN on the yellow door sticker is the FL VIN.
Paul
Paulie Boy is offline   Reply With Quote
Old 10-21-2015, 09:11 AM   #70
accumack's Avatar
Correction mine is z050682 not 32 so we are only 2 apart I misread the number on paper work when I looked at the label I saw the correct number. So Boo my chassis is 4 older than yours but the coach is 2 newer they must have been built the same week.
Ham KG5LTL.
fan
