Old 11-29-2014, 10:07 AM   #1
gasman94's Avatar
Shower water fixture
I don't know what made me think of this since my Berk is in bed for the winter, but just curious if anyone else has had a problem bumping the fixture while taking a shower. I've done this several times and it is so sensitive to hitting it that the water temp fluctuates quite a bit when bumped. I'm wondering if I can change it to a unit like I have in my house.
Rich
gasman94 is offline   Reply With Quote
Old 11-29-2014, 08:46 PM   #2
Berkshire 390QS
NO3putt's Avatar
Ours is very touchee, would like to change ours out also, just haven't taken the time to take out and just see if there is any difference between the one installed and one we could buy at Lowes or Home Depot.
Skip
Old 11-29-2014, 11:24 PM   #3
gasman94's Avatar
Skip, if you do, let me know what you find out. I will do likewise.
Rich
Old 11-30-2014, 06:49 AM   #4
cpaulsen's Avatar
Just go to the big box stores and see what they have....shower fixture is most likely 4" centers .......just check to see where the hose connects to.
cpaulsen is offline   Reply With Quote
Old 11-30-2014, 08:49 AM   #5
I-RV's Avatar
I would also like to change, but for a different reason. With the tankless water heater, Girard says that you should adjust water temp. with flow rate, rather then mixing some cold water. I find that on my 2012 Berk, that it is very difficult to adjust the control for a little bit more cold water when the handle is out.
X2 with interest for anyone that has changed their shower control.
I-RV is offline   Reply With Quote
Old 11-30-2014, 09:15 AM   #6
AREA51's Avatar
Shower Fixture
gasman94,
My solution was Weight Watchers.
Good Luck,
AREA51
AREA51 is offline   Reply With Quote
Old 11-30-2014, 09:18 AM   #7
gasman94's Avatar
Originally Posted by AREA51 View Post
gasman94,
Good Luck,
AREA51
Nice......lol
Old 11-30-2014, 09:29 AM   #8
AREA51's Avatar
Shower Fixture
gasman94
It did not work for me.
Good luck,
AREA51
Old 12-03-2014, 04:41 PM   #9
Berkshire 390QS
NO3putt's Avatar
Got the shower valve out, not a problem but having problems finding one with the same fittings on back, tryed Lowes, Momen brand did not match up. Guess tomorrow off to run around town and plumbing supply store to look. Picture of back of valve below.
Old 12-04-2014, 04:43 AM   #10
gasman94's Avatar
Attachment 67072
That was my concern....that fixture plumbing would not be the same.
Rich
show, shower, water
