Old 07-01-2015, 12:31 PM   #1
DJP6371's Avatar
Sirius Radio Antenna
I have recently hooked up a Sirius radio to my RVs Jensen radio, and it works great!
The antenna that comes with it, I currently have sitting on the dash. I find that reception is intermittent in that location.
I am guessing I am going to have to put it on the roof. Has anyone run an antenna through the roof into the RV, and if so how did you do it?
Sent from my iPhone 'cause I'm probably out in the RV!
DJP6371 is offline   Reply With Quote
Old 07-01-2015, 12:43 PM   #2
BendOrLarry's Avatar
I have a Sunseeker 2860ds ford cassis. I mounted my magnetic XM antenna on the hood just in front of the windshield. It doesn't move and the signal is consistent.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 07-01-2015, 01:04 PM   #3
silver's Avatar
Try getting a 6 inch square piece of metal to put the antenna on. It is looking for a ground plane. Made a big difference for me and I have had antenna inside the Berk for 5 years now. works great. did not work befroe the metal.
silver is offline   Reply With Quote
Old 07-01-2015, 01:45 PM   #4
DJP6371's Avatar
Thanks...I'll give that a try.
Old 07-01-2015, 06:31 PM   #5
oldkeywest91's Avatar
I do not see any where which Berkshire you have but on our 38A there is a ledge on top of the windshield that the sun shield is mounted too.I ran the XM wire up the drivers side of the molding and placed the antenna on the shelf.It does not have to be metal to work just high enough so receive a good signal.Hope this helps
oldkeywest91 is offline   Reply With Quote
Old 07-01-2015, 08:31 PM   #6
ernest917's Avatar
I used industrial strength Velcro and placed the antenna in the middle top of the windshield and ran the wire down the windshield by the center column.... (My 2008 has the split windshield). Works great....
ernest917 is offline   Reply With Quote
Old 07-01-2015, 08:45 PM   #7
B and B's Avatar
Sirius antenna does not need a ground plane like a CB antenna. You can just stick it to the Roof. I did this with some Dicor sealant, works great!
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-02-2015, 10:19 AM   #8
7 Year Class A RV'er
I can't say either way on the ground plane thing. I've seen arguments that it worked when a piece of metal was added and other arguments that it isn't needed, just like these posts. I haven't tried the metal on the dash but may do it just to see. The biggest issue I know of with putting the antenna on the dash, windshield or anywhere other than the roof is the satellite location. The Sirius XM satellites, like most others, are orbiting over the equator. Since I'm north of the equator, with the antenna sitting on the dash, I get great reception when driving south, pretty reliable with heading east of west and absolutely no reception when heading north. Fiberglass in the RV skin is transparent to the signal, but mass will block it just the same, so upper cabinets, structural framing, etc. will kill the signal. Wish I knew an easy way to get it on the roof but I don't want to go drilling holes.
2015 Legacy SR340 360RB
Old 07-02-2015, 12:38 PM   #9
EJM4's Avatar
X2 on what Oldkeywest said. Works like a gem in my 39BH.
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 07-02-2015, 04:07 PM   #10
CONCEPTUMATOR, You have the same shelf as the 38A and if you place the antenna face up in the shelf it is out of the way from any interference.Have no problem receiving signal while driving North,South,East or West.As for the magnet on the antenna it is to hold the antenna on the cars and that is all.
antenna, radio
