Old 06-26-2010, 05:59 PM   #1
2011 Berkshire 390bh
wnytaxman's Avatar
Sirius Radio Hookup
When we tried to hook up our Sirius Radio we had an issue with the Jensen unit in the coach. We had a portable unit that I had used in my Mini Cooper, but I wasn't too keen on having it broadcast into the FM station and using it while traveling as it is fairly common to get interference from local radio stations. What worked for us is to set the antenna on the dash and run the wire under the removable panel over the radio. Then we put the portable unit in the cup holder and ran a connection directly into the radio wires in the back of the Jensen. I can access the Sirius by setting the Jensen to Aux and letting the Sirius go right into the audio system. Total cost, with labor and materials was under $50. Had I known how easy it was to do I would have done it myself and I'm a totally dummy about electronics and anything mechanical.
wnytaxman is offline   Reply With Quote
berkshire, surveyor
