05-15-2018, 07:38 PM
SIriusXM Radio for Magnadyne M10
I have been doing some research so we can set up XM Radio in our 2018 34QS, so I figured I would share what I have figured out so far. Under the dash access, you will find a black cable with a cover on the end and the cable is labeled XM Radio. You will need to purchase a SIriusXM SXV300V1 tuner kit. You can buy one from XM on their website for $69.95 or you can get one on Amazon for $40.49 if you have Amazon Prime. There is a lot of open space behind the radio to mount the tuner and then you have easy access to run the antenna.
I ordered one today and won't be able to install it for a couple of weeks, but I wanted to at least share what I figured out.
I'll post pictures and comments about the install when I get it done this month.
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
05-15-2018, 07:42 PM
Thank you. We appreciate the info and we look forward to seeing the pictures.
Karen and Rick
2020 Forester 2251SLE
Previous: 2018 Berkshire XL 40C
2011 Honda CR-V toad
07-18-2018, 12:04 PM
FYI, my 2019 XL 40C already had the Sirius antenna pre-installed up on the roof. You just need to get the tuner kit and connect it to the radio on one end and the pre-installed antenna cable on the other. Very simple.
07-18-2018, 12:08 PM
if you have sirius radio in a vehicle you already have, you can listen online for free, just saying
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
09-30-2018, 05:46 PM
Sorry, I took a long time to get around to doing this project. Pretty simple. Plug the unit into the cable on the back of the radio and run the antenna. All I did was set the antenna on the dash. I can run the antenna wire under and over to the side window, but I'm going to see how reception is as installed first.
2020 S.O.B.
10-03-2018, 06:08 AM
Other option
First off, let me say Oscar's solution is the best.
You might have better luck than me due to location. I am in New Brunswick, and the signal was dropped approximately 10 % of the time with the antenna located where you show it.
So I re-routed the black puck to the roof, by going up the slide seal behind the driver's seat. Once I got it to the roof, I stuck it on the metal plate next to my dish. Some gorilla tape to keep with wire from flapping in the wind, and all is good. Not the prettiest install, but definitely functional.
Now I get reception 100 % of the time while on road.
2018 FR Berkshire XL 40 C
2019 Jeep Wrangler
10-03-2018, 07:32 AM
I can't believe that a 2018 Berkshire doesn't come with a fully functioning XM radio from the factory.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
10-03-2018, 08:12 AM
The 2019’s have the antenna installed from the factory. Still need the XM module.
10-03-2018, 09:35 AM
Dragonship Captain
Boggles my mind too... Less than $100 for them to easily install it.... And they could have the trial deal with Sirius/XM.....
Now we're ALL putting time and effort in to making this work.
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
10-03-2018, 10:06 AM
Even worse, you can buy the antenna for $29.00 or you can buy the receiver module that includes the antenna for $ 49.00
2020 S.O.B.
10-03-2018, 10:18 AM
Dragonship Captain
I was giving them credit for an hour of assembly time which is probably too much when they're running all the cables anyways.....
10-29-2018, 10:19 AM
Depending on your radio, xm set up is no longer required if you have Blue tooth. All that is needed is to get steaming from XM to listen to anything that you subscribe to. Very easy for adding 5.00 bucks to your contract for a year, works great no new antenna or radio head needed, works great if you have Blue tooth on your recivier
Coachmen M/H
Concord
2018 / 300 DSC
