Old 11-13-2013, 11:13 PM   #11
Campin Cajun's Avatar
Same here, I have to slam ours also to get a tight seal. I only do this when we are about to drive or when we go to sleep. Otherwise I just close it normally when we are camping and going in and out the coach.
It has a double locking mechanism just like a car door.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-13-2013, 11:34 PM   #12
edgewant's Avatar
Located the following and it seems to describe my door and how to adjust it. Am going to try it tomorrow.
File Type: pdf PTL Preferred Door Latch Adjustment.pdf (4.70 MB, 155 views)
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 11-14-2013, 12:59 PM   #13
edgewant's Avatar
The above adjustment worked and I backed off on the star wheels only one cog. Haven't road tested yet but it is much easier to close. Now we've got to break the habit of slamming it. Will update once I have a chance to road test.
edgewant
Old 11-14-2013, 03:07 PM   #14
mjracsj's Avatar
I would be curious not only about how you make out with a road test but also maybe do a rain or water test. When we got our coach new from the dealer the door didnt need to be slammed but I noticed a bit of water (and resulting rust) on top of the door and the double catch didnt work it was just a single click. On my next visit back for service to ask about this their one (and only) knowledgeable tech told me that it should work as a double catch(push lightly for first click and door is closed but maybe not totally sealed) or push hard (or slam) and it is sealed tight and safe for the road although we lock it anyway while in motion. He tinkered with the adjustment and yes we need to slam or at least close it very firmly but it works and we want to stick with it that way. If it is set up right you should push lightly and hear a click then push again more formly and hear it click again. I believe that is why the latching post is designed to have a bit of movement in it.
mjracsj is offline   Reply With Quote
Old 11-14-2013, 03:24 PM   #15
edgewant's Avatar
Well I really had to slam mine to get it to latch on the second detent. I really didn't care for it the way it was. However I really won't like it either if I have water leaks or wind noise. I did place a piece of paper between the weather seal and door and closed it and tried to pull it out. I repeated this around the perimeter of the door and had resistance at all locations. I'm waiting for my co-pilot to get off work before road testing so she can tell me if she hears anything like wind noise or rattles. If that goes well then while it's out of the garage I'm going to get the hose after it and test for water tightness.
edgewant
Old 11-14-2013, 04:06 PM   #16
Edge, yes 2112 Berkshire.
Mike
mcomer is offline   Reply With Quote
Old 11-14-2013, 08:34 PM   #17
VinceU's Avatar
Try a "caulk" test first before water. The result will show not only a leak potential but also exactly where. Simply apply a heavy application of dry marker chalk to the thin edge of the gasket. Close the door normally and when you re-open you'll see a faint trace of where the chalk has transferred to the steel frame. This test is used by the Navy and Merchant Marine where water integrity is important. Most used on Duct work and vent openings to ensure if vessel is taking water, it won't sink due to leaking doors.
The cam pin design is used on the automotive style lock, not yours, found both online by PTL
Old 11-14-2013, 08:53 PM   #18
edgewant's Avatar
VinceU
My latch is the cam pin design. Had it apart and moved the cam by one cog. The document I posted was a great description of how to adjust the latch. Not sure why you think my latch is not like what is depicted in that document!
edgewant
Old 11-14-2013, 09:07 PM   #19
VinceU's Avatar
VinceU
Actually I do agree with you, my Engineering is better than my English,
"The cam pin design is used on the automotive style lock, not yours, found both online by PTL" that's what this said! Same company, different design. One of the posts 3 or 4 back(Campin Cajun) says he has the automotive design latch. Both are covered in their web site.
The test will work with any flat gasket surface. Better than blind test with water.
Old 11-14-2013, 09:17 PM   #20
edgewant's Avatar
Whatever!
edgewant
door
