Old 10-05-2015, 12:14 AM   #1
jegstrup's Avatar
Slide out cargo tray
I've been thinking about the 1000 lb people/cargo weight limit on my Berk and how to deal with that.
Has anyone considered removing the slide out cargo tray, and how much weight would this free up?
Thoughts?
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
jegstrup is offline   Reply With Quote
Old 10-05-2015, 07:33 AM   #2
silver's Avatar
I would bet that would save a couple hundred of pounds. I also removed the 1/2 inch particle board cover under my bed. I figured just dead (20 lbs or so) weight and I know not to put things there. There was a metal screen covering my inverter (and before the systematic police chime in it is called an inverter by Magnum Enegery) that is also gone. I go through the coach every spring and ask what can I remove for weight savings.
silver is offline   Reply With Quote
Old 10-05-2015, 08:14 AM   #3
mark0224's Avatar
I know I don't have a MH but as silver has said I try every year to get a little lighter. Lighter weight lawn chairs, a gas grill /stove and a very small charcoal grill and just as much charcoal as we need for that trip. We didn't need a kitchen service for eight cut that to 4. Pots and pans aluminum and just the basics. Water Hose was a big item i got rid of, kept 50 ft of white hose but got rid of 200 ft of regular hose and got 200 ft of that light weight expandable lost 30 lbs doing this. Expandable works great for filling water tank without moving to get to spigot. Next weight loss wil be tools and setting up a basic tool kit bet I can loose 30 lbs there.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-05-2015, 12:26 PM   #4
Same here, but i bought that rubber Expandable hose, looking at the box it said DO NOT USE FOR DRINKING WATER BY HUMANS. So I don't use it. Maybe they made one with out the chemicals the use for the Expandable part. Will use it to wash RV. Tools broke it down to what i need for basic work. I try not to carry to much Junk.
outloud is offline   Reply With Quote
Old 10-05-2015, 05:20 PM   #5
gasman94's Avatar
Why only 1000 lb? 340 hp?
Rich
gasman94 is offline   Reply With Quote
Old 10-05-2015, 06:17 PM   #6
jegstrup's Avatar
Yea, that's the max cargo weight for my rig
Old 10-05-2015, 06:36 PM   #7
Something isn't right. I have a 2011 RB with more than that.
Old 10-05-2015, 06:38 PM   #8
jegstrup's Avatar
That's what the weight sticker on the screen door says.
The combined weight of occupants and cargo should never excess 1022 lbs
Old 10-05-2015, 06:40 PM   #9
Have you weighed it?
Old 10-05-2015, 06:41 PM   #10
jegstrup's Avatar
Not yet, planning to do that before I hit the road. Will the truck weigh stations let me weigh there?
Old 10-05-2015, 06:42 PM   #11
Yes they will. One payment is usually good for the day. That would allow you to get weight with empty water and full water. Full fuel ect.
Old 10-05-2015, 06:44 PM   #12
What tires size do you have?
Old 10-05-2015, 07:25 PM   #13
mark0224's Avatar
We don't drink the water from any hose we bring 5 gal containers of water from home also like we treat black and gray tanks I treat fresh water tank always add a little chlorine whenever its filled.
Old 10-06-2015, 08:42 AM   #14
I-RV's Avatar
Oh yes, my yellow sticker states that the combined weight of cargo and passengers should not exceed 1,344 lbs. It also cautions that a full load of water will be 716 lbs. So as I figure it, after putting my DW and me in, there is enough capacity to carry a lunch bag.
However, I did have my tires up-sized and front suspension capacity increased to 12,000 lbs.
I mentioned time after time in this forum that everyone should get their rig weighed, loaded.
FR selects a Freightliner chassis which will carry loads; but then they keep piling weight on top of it. Originally there was no tile floors. Tile is heavy.
Even the new tag axle with over 4,000 lbs capacity has this capacity diminished when you put 200 gallons of fuel I, 126 gallons of water and a full load of passengers. - Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 10-06-2015, 10:41 AM   #15
jegstrup's Avatar
My tires are rated for 5600 lbs each, don't know yet about the axles, and haven't weighed yet but will when I pull out of the patk
Old 10-06-2015, 11:32 AM   #16
360true's Avatar
Losing Weight
I conferred with my DW about how to shed a few pounds and she told me to stop drinking beer! Guess the rig is going to stay heavy.
360true is offline   Reply With Quote
Old 10-06-2015, 11:33 AM   #17
accumack's Avatar
My Berkshire has 100 gallon fuel tank and a 86 gallon water tank. Is yours different. I would never drive with a full tank of water extra weight.
edit:I see it's the new tag axle Berk
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 10-06-2015, 11:39 AM   #18
Just Dreamin
dreamin533's Avatar
Hi all, just thought I would throw in my 2 cents. I took the coach to the CAT scales at a truck stop here in Ontario and I thought I was getting close to the max but not so. The coach had almost a full tank (100 gallons) fuel, 2/3 tank of water, all the normal camping stuff, DW and I but no food or extra clothes and mine weighed 9100 lbs, front axle and 16900 lbs, rear axle. I have a max rating of 29500 with the mercedes engine in a 2008 Berkshire 360QS so I was quite surprised that I have over 3000 lbs of cargo carrying capacity. I have upgraded the tires from 255/80r22.5 to 275/70r22.5 and I don't have to run as high pressures for the max weight and it makes for a more comfortable ride.
dreamin533 is offline   Reply With Quote
Old 10-06-2015, 11:54 AM   #19
I-RV's Avatar
You must be running helium in your tires and probably do not have a ceramic tile floor - LOL I have the tire and axle upgrade, which is great. - Hank
Old 10-06-2015, 12:20 PM   #20
MilCop4523's Avatar
We dont eat before hauling... saves a good 5 lbs there...
and the Air in the tires @ 80 lbs of pressure each
possible more savings if you take one roll of TP instead of trucking 4 or 5 back and forth.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
slide, slide out
