11-13-2014, 10:04 PM
#21
How long is that slide.
I have a 2013 390RB and while I don't have any deep depressions in the slide bottoms from the rollers, my dinette slide does protrude about 1/2 to 5/8 in at the forward and aft bottom corners. The bottom center of my dinette slide actually makes contact with the body of the motorhome so maybe my slide frame is warped also. It's not a huge issue since I have no leaks...just seems like it ought to fit better.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
11-13-2014, 11:47 PM
#22
Mine is an RB also. From what I remember from looking underneath , I think those plates would only work on the kitchen side. I was planning on calling Randy for some other things I'm going to ask about the slide plates for the RB.
Dan
2014 Berkshire 390RB-60
11-14-2014, 01:38 AM
#23
Would you please post whatever Randy tells you.
edgewant
11-14-2014, 07:36 AM
#24
I certainly will,
Dan
11-14-2014, 08:17 PM
#25
Originally Posted by JTN8
I just noticed there are not any rubber flaps across to keep the bugs out?
I was looking at my 2014 390RB and had to pull the flap back to see the rollers.
Dan
11-15-2014, 12:55 PM
#26
On that slide, the rubber flap is behind the rollers. All the other slides, the flap covers the rollers up. Not sure why that one is different.
Jason
11-15-2014, 03:00 PM
#27
Not on my 2013 390RB. It's on the outside and covers the rollers up. That particular seal did not fit very well on motorhome so I fabricated a different one that does a much better job of sealing the bottom on that slide. The original allowed a lot of outside air infiltration.
edgewant
11-15-2014, 03:32 PM
#28
Berkshire 390QS
They replaced our outside seal at Goshen in August since air and light was comming in, also the bedroom seal was replaced.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
11-15-2014, 03:42 PM
#29
Was the replacement the same as the original? By that I mean is it a wiper seal? If not could you post a pic of the new seal?
edgewant
11-15-2014, 03:44 PM
#30
No3putt: Are there more than 1 bedroom slide on your floorplan? If so which one was replaced and a picture of that would be of interest too.
edgewant
11-16-2014, 12:16 AM
#31
Berkshire 390QS
We have bed slide and dresser side, bed side on drivers side. Will post picture when the weather get above freezing and snow melts a bit. Snowing right now, should be in TX with Phil and not in CO. It's a wiper type seal, have them on all four slides.
11-16-2014, 08:38 AM
#32
Do not own a MH, but one of my slides have the same rollers. All the geared slides have a wiper outside, but the small one with the roller it is attached inside. Which I found surprising.
Coachmen M/H
Concord
2018 / 300 DSC
11-16-2014, 10:25 AM
#33
3putt,
I had the same thing on my '08. Seems that they changed things and stopped putting the wiper seal on the bunk slide a year or 2 ago. I don't like the idea of the bottom of the slide 'open' like that without any type of 'protection' from the weather and bugs.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
11-16-2014, 04:10 PM
#34
Originally Posted by tmmar
3putt,
Tom
I just went and checked my slide with the rollers. The sweeper is inside the unit not on the outside, so there is still a seal from bugs and water and the elements. But Please remember mine is NOT a MH, all I can say is that's how they designed that slide on a Rockwood. I would think they wouldn't leave that space open on any unit, BUT again this is FR.....
Coachmen M/H
Concord
2018 / 300 DSC
11-16-2014, 05:00 PM
#35
On my 14 390BH, it does have a rubber sweep seal on the bunk slide, but it is behind the rollers. All the other slides have the seal in front of the rollers. Not sure why that one is different
Jason
2014 Berkshire 390BH
2011 cadillac SRX
11-18-2014, 01:51 PM
#36
Originally Posted by dan-nickie
I certainly will,
I am in email contact with Randy.
No final answer yet.
Will advise.
Dan
11-18-2014, 07:34 PM
#37
Will advise.
Same here, he asked for my serial # and where I am from. No word back as of yet.
2013 Berkshire 390BH
11-19-2014, 08:19 AM
#38
Spoke with Randy this morning about my slide alignment issue. He stated that he'd rather have FR do the fix at the plant. Hopefully we'll be able to get the coach up there to get it right. More to follow.
Jason
11-20-2014, 09:11 AM
#39
Two years ago, my bunk slide was depositing aluminum shavings on the inside floor. The shavings culprit was found to be the bunk floor indenting, which caused the internal weather seal with its aluminum binder to scrape,
Randy authorized the repair which included removing the bunk slide and for a total of 19 hrs. labor. When it came time to do the repair, FR gulped on the 19 hrs. and instead, the internal seal was fished out and an external rubber flap seal was installed. FR sent five heavy duty steel plates, but Lazydays said that was a lot of weight and not needed. So far, almost two years later, all is good.
I am not sure what kind of bottom seal, FR is using now.
11-27-2014, 05:19 PM
#40
Will advise.
Just an update. Randy has not given me an answer on the slide plates at all. Having trouble getting email responses back.
Dan
