Old 05-26-2013, 09:22 PM   #1
DannyV's Avatar
Slide out topper
I have a 2013 BERK 390BH I bought this past Feb. I've driven it in Texas and California during windy conditions (20-30 mph) and in both cases have had the left front slide out topper start to spool off the reel.
After the first incident I took it back to the dealer and they had Carefree replace it. But it has done it again.
Am I the only one having this problem?
I'm beginning to think it is a design problem.
Danny
DannyV is offline   Reply With Quote
Old 05-26-2013, 10:46 PM   #2
Himcules's Avatar
i've been out 3 times with my 2013 390bh but all 3 were 1hr drive each direction. one time was very windy with a strong side wind that pushed against the rv that you can seriously feel, but no issues with the slide toppers on mine.
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 05-27-2013, 09:30 AM   #3
Future Berkshire Owner
Joker's Avatar
I have had my sofa slide topper spool out like a giant sail, oh maybe 50 times. Almost always driving somewhere between the panhandle of Texas and southern Colorado. The quick fix is to put some pieces of duct tape from the little deflector to the roll. This can be done by leaning out the windows from the couch and dinette-- if you are agile enough! I have also had the wardrobe slide topper spool out a couple of times.
It seems to me that a permanent fix would either need a different shaped wind deflector or some sort of clips. Btw, if you leave the tape on by mistake and extend the slideout, the system is strong enough to tear through at least 7 pieces of duct tape, although mine did make some noises in protest!!
I'm still wondering if there's some adjustment I can make to the little deflector shield.
Joker is offline   Reply With Quote
Old 05-27-2013, 10:02 AM   #4
ernest917's Avatar
Had the same issue with my 2008... Mine was on curb side kitchen slide... Topper came completely unrolled, ripped and twisted... Had to end up cutting it off so I could open the slide... A few hundred bucks later, I had a new one installed...
I believe the problem is the wind deflector on the front of it simply doesn't do what it was designed to do.... The toppers need some sort of cover on them I guess, but that would be a pain because of having to remove and replace the over and over....
ernest917 is online now   Reply With Quote
Old 05-27-2013, 10:58 AM   #5
Maybe I'm on the bleeding edge on this one (for once!!). When I got my 2011, the slide topper rollers (with the material wrapped around them) were exposed to the elements. I figured FR had forgotten to install the covers, but they are apparently optional from Carefree.
Randy Hauser told me that FR has never put the covers on. So, I asked my tech about it, and he ordered the covers so the rollers themselves would be completely covered.
I figured it was only cosmetic, so when I got the bill I freaked out. $1400 for four slides!!! Made the silly assumption that $500 would cover it. So maybe with this new issue coming up, I'm actually ahead of the curve??
Oh, and they DO make a real SHARP cosmetic improvement.....
Anyone else have covers on the rollers? If so, did FR install them at manufacture?
Boowho??
boowho is offline   Reply With Quote
Old 05-27-2013, 11:32 AM   #6
Himcules's Avatar
Boowho??
can you post some pics of your covers? i'm interested in this... thx
Old 05-27-2013, 12:01 PM   #7
ernest917's Avatar
Hey guys.... I may have found the solution..
Check out web site for Awning Pro-Tech.... They have a 5 piece set of covers that will protect over 20' of awnings for $119.00... Transportation clips (which let you travel with them installed) are included...
Let me know what you think...
Old 05-27-2013, 12:06 PM   #8
Owner/Operator
RodeoGeorge's Avatar
My Slide Toppers on the 8289WS came with the Anti Billow Hardware. A lever that, when the slide is retracted, prevents the roller from moving. I believe that it's standard on the Dometic Slide Toppers.
Here's a link to the hardware:
Dometic 3109252.001 Anti-Billow Assembly Hardware Part Camper Trailer RV
I have seen some posts about the hardware not being properly adjusted though.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 05-27-2013, 12:11 PM   #9
Owner/Operator
There are some posts here on the forum about what a pain it is to put them on and take them off. You need a ladder to do it.
RodeoGeorge
Old 05-27-2013, 12:11 PM   #10
Himcules's Avatar
i think you need to either carry a tall ladder with you or climb on top of the roof to install these on to the awnings when you are ready. from one of the videos, i think they said you can leave them on and extend your awning like normal where they just pop right off.
either way, it's not as clean and self contained as the solution boowho bought from carefree... its not as expensive either tho...
