Old 03-04-2015, 09:13 AM   #1
jmgllt's Avatar
Slide outs!
I live in southeast Louisiana and having problems with my slide outs. Looking for a reliable repair shop that I can trust! Any suggestions!
jmgllt is offline   Reply With Quote
Old 03-04-2015, 12:16 PM   #2
silver's Avatar
Which slide and what is the problem. Perhaps someone on the forum can suggest a fix.
silver is offline   Reply With Quote
Old 03-04-2015, 12:22 PM   #3
jmgllt's Avatar
Bedroom slide it starts to slide and stops apply a little pressure and it slides out. The kitchen and living room side tend to come out a little after heading down the road
Old 03-04-2015, 03:45 PM   #4
Mmnsc's Avatar
The kitchen and living room slides are hydralic and the creeping out is usually a worn cylinder and/or the anti creep valve. Bad news it tends to get worse over time. It has happened to many of us owners. The bedroom slide, is it the bed or the wardrobe side. Usually the bed is rack and pinion and the other is cable. You might have a misalignment and by pushing it you over come the force to move it. Get it looked asap so not to get stuck somewhere.
Mmnsc is offline   Reply With Quote
Old 03-04-2015, 04:57 PM   #5
2011 Berkshire 390BH
Superchief's Avatar
Jmglit,
Follow this link if it is the bed slide that you are having issues with. It should help you.
Bed Slide Problem
Craig
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 03-04-2015, 06:04 PM   #6
dan-nickie's Avatar
For the Kitchen and Living Room hydraulic slides, you should first check your fluid level.
Mine was low about a quart. After adding the fluid I have not had a problem. Simple.
I know this has not helped on others, but worked for me so far.
Note that the slides need to be IN and the jacks UP to check the fluid level.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 03-04-2015, 06:12 PM   #7
Witch Doctor's Avatar
check for leaks?
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-04-2015, 07:25 PM   #8
silver's Avatar
As stated in another post the kitchen and living room slides are Equalizer slides and hydraulic. It could be fluid level or the anti creep valve. You may want to go to the equalizer web page and pull the manual. Make sure who ever works on it knows what they are doing. You may want to use your slide locks until you get it corrected.
The bed slid if queen or king bed is a rack and pinion slide by Equalizer. The motor loosens and slips down causing the slide to slip. Attached is a picture showing the four bolts that loosen. If lucky all you will need to do is push the motor back up and tighten. On mine the casting broke so I had repair the casting and fabricate a bracket to hold the motor. I think it is a poor design.
Name:	bed slide.jpg
Old 03-04-2015, 07:35 PM   #9
jmgllt's Avatar
Thanks I'll check all this out tomorrow !
Old 03-04-2015, 07:36 PM   #10
jmgllt's Avatar
Oh and it's the bed side of the bedroom.
slide, slide out
