Old 09-04-2013, 12:24 PM   #11
NV245's Avatar
That appears to be a flexible driveshaft similar to what is used on power seats. Mechanical speedometers had a similar cable. It shouldn't be too hard to replace, if the shaft can be found separately. But, something caused it to twist and pull out/break. Look for something binding before attempting to operate after repair.
NV245 is offline   Reply With Quote
Old 09-07-2013, 09:16 PM   #12
LisaBush's Avatar
Wow, have the same exact problem with my 2013 Berk. Took it to the dealer today, hopefully won't tell us it not under warranty. Went out last weekend and the bed slide would not go out, could hear the motor running, but not moving at all. We just bought it in January.
LisaBush is offline   Reply With Quote
Old 09-08-2013, 09:28 AM   #13
tmmar's Avatar
Lisa,
If it is the slide for the bed, lift the bed and look for a broken shear pin on the slide mechanism.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 09-08-2013, 01:27 PM   #14
LisaBush's Avatar
Thanks. We took it to our dealer yesterday. We had a couple of other items that needed fixing.
Old 10-11-2013, 05:09 PM   #15
Campin Cajun's Avatar
I wanted to update this problem.
It was the soft shaft from the electric motor to the gearbox that was broken. Warranty covered the repair.
Last time I had the coach in for some other services the kitchen floor was gouged. The dealer covered the cost of that too.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 08-10-2014, 09:47 AM   #16
Can you e-mail me a lit of parts/repair needed? I have a 2013 390BH and the slide is stuck in. My pix look very much like yours--the thing connecting the motor and gear box looks like some thin shaft that has silver tinsel wrapped around it. Motor runs but no tension on the chains, so I think the gear box is not engaged.
I am trying to advance order parts so I don't have to leave it at the dealer for an extended time while they figure it out.
sean
seanfulton is offline   Reply With Quote
Old 08-10-2014, 10:01 AM   #17
Sean I am away from home until the 13th, when I get home I'll look for the paperwork and send it to you.
2013 Berkshire 390 BH
Old 08-10-2014, 11:33 AM   #18
Thanks. For anyone else looking, here is a hi-res pix of my unit. Suggestions/similar stories appreciated.
Old 08-10-2014, 05:25 PM   #19
Yup that's the same thing that broke on mine.
Sean I tried emailing you back but it's coming back as undeliverable. I'll send you the info in a pm.
Old 08-10-2014, 10:24 PM   #20
Please send to me as well. I want to be prepared.
Steve.heicklen is offline   Reply With Quote
