Old 07-31-2015, 06:13 PM   #1
gasman94's Avatar
slide seal maintenance
Anyone have any suggestions on how to apply chemicals/preservatives to the top of the slide seals under the slide topper? How do you reach to the inside?
Rich
gasman94 is offline   Reply With Quote
Old 07-31-2015, 10:24 PM   #2
UmptySquat's Avatar
I just use a rag. If I wipe the outside seals first it gets pretty saturated. I spray some protectant under the outer seal to the inner and wipe it with the rag. I've found it does a great job.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 07-31-2015, 11:15 PM   #3
dan-nickie's Avatar
For those tough to reach places, I have seen one member post that he wraps some socks around an extension pole.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 08-01-2015, 08:56 AM   #4
Aerospace 303 applied by spraying on and wiping down with a clean sponge. Use the 303 on your tires too! It's like sunscreen for premature sidewall aging and cracking.
Paulie Boy is offline   Reply With Quote
Old 08-01-2015, 11:55 AM   #5
It's not so easy as just spray and wipe when talking about the top seal under the slide out cover. I have done mine from a ladder but I can't reach all the way. I guess the good news is they are protected so the treatment isn't as important.
Old 08-01-2015, 12:28 PM   #6
Phil, I took a new tennis ball, put a hole in it and screwed onto one of telescoping wash poles. Saturated the tennis ball and coated the gasket. I'm anal, I know!
Old 08-01-2015, 02:23 PM   #7
gasman94's Avatar
Well, I took one of those telescoping wash poles and taped a padded sock to it, saturated it with 303 and did the best I could to cover the seals. I think next time I am going to try to fix a sponge on the end and saturate it before using. Thanks for all of the suggestions.
Rich
Old 08-04-2015, 12:43 PM   #8
I sprayed the silicone/lubricant on one of those short paint rollers for smooth surfaces and used an extension handle. Worked great.
81redbug is offline   Reply With Quote
Old 08-04-2015, 12:54 PM   #9
Senior Member - Retired
Which Aerospace 303 Product
Which Aerospace 303 product is best for slide seals. They make several including 303 Aerospace Cleaner, 303 Aerospace Protectant, 303 Vinyl & Fabric Convertible Top Cleaner and 303 Fabric Guard?
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is online now   Reply With Quote
Old 08-04-2015, 06:28 PM   #10
Aerospace 303 Protectorant is best for the seals, tires and dashboard of the coach. IMO
Paul
maintenance, slide
