Old 08-07-2010, 03:52 PM   #1
Slideout Grease Fittings
While rearranging the storage compartment I noticed that there are grease fittings for the slideouts. I looked through the owners manual to find out which grease to use, but couldn't find out any info. Has anyone here greased theirs yet and what grease did you use?
2008 Forest River Berkshire 390QS
2006 Ford Focus Toad
Sometimes 6X12 enclosed trailer with a
2007 1200c HD Sportster & a 2006
HD Night Train
06nighttrain is offline   Reply With Quote
Old 08-07-2010, 04:43 PM   #2
NWJeeper's Avatar
Where are they located? I have not seen any on ours and there is no mention of it in our materials from Lippert. I suppose you might have a different brand mechanism than ours though. I would guess a good lithium grease would work well.
Ed & Wendy
www.nwjeepn.com
Old 08-10-2010, 12:09 AM   #3
They are located under the floor of the kitchen slideout & the sofa slideout. They are visible from the underbelly storage area. It appears that there are two arms that are mounted under the flooring that keep the slideout traveling straight by being attached to a rod in between the arms with a bearing & grease fitting at each end of rod. The 2 slideouts for the bedroom are smaller & I haven't found grease fittings on them.
The slideout manufacturer is HWH. I looked around on their website, but couldn't find any helpful info.
HD Night Train
Old 08-10-2010, 12:12 AM   #4
Tmmar have you noticed these grease fittings on your kitchen & sofa slides? I saw where your MH is a 2008 also.
HD Night Train
berkshire, surveyor
