sounds like the symptoms of low HOUSE batteries, must not have been charged while traveling - did you accidentally hit the 'STORE' switch? If so, the House batteries probably would not have been charged while traveling.
Start the generator, if not on shore power, make sure the switch is in the 'USE' position, and you should then have 12v power to the slides and water heater(thermostat).
The Turners...
