Old 01-12-2015, 08:55 AM   #1
Fulltime in our Berkshire
KennyGolub's Avatar
Smoke from Fireplace
It is too cold to go into the coach and pull out the fireplace, so I thought I'd throw this out here to see if anyone else had the same thing happen, and thereby saving me some time.
I go out to the coach every two or three weeks to run the genny and put a load on it my turning on the TVs and the electric fireplace.
On two occasions, I got a wisp of smoke coming out of the fireplace. After a minute it stops. This doesn't happen every time either.
Has anyone else have this happen ?
Thanks,
Ken
KennyGolub is offline   Reply With Quote
Old 01-12-2015, 09:02 AM   #2
MtnGuy's Avatar
Burning some dust off the heating element ??
Old 01-12-2015, 09:04 AM   #3
Kaadk's Avatar
We're talking an electric fireplace right? I certainly hope you're not lighting a fire in your motorhome.
Seriously though, if it's like our fireplace at home, it might just be dust burning off. Or you might have a real issue. No way to be certain unless you pull the unit and look for burn marks.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 01-12-2015, 09:41 AM   #4
KennyGolub's Avatar
I'm thinking that will be first on the list after I take the cover off.
I had another thought that I don't like, although I'm hoping it's not likely....wondering if maybe some field mice decided they wanted to travel in the spring and began to move in early, building a nest near a heating element. Sure hope not.
Guess I'll just have to wait for some warmer weather.
Thanks.
Old 01-12-2015, 09:43 AM   #5
KennyGolub's Avatar
That is very possible as it is a new coach, and I can see all kinds of dust and even saw dust in the furnace registers on the floor.
Thanks for the reply.
Old 01-12-2015, 09:50 AM   #6
Infractee
Thanks,
Ken
What does it smell like would be the most important thing to know. If a home heater fired up for the first time since last winter smell that would be okay, if an electrical smell that would be bad.
Have used the fireplace on our new camper during 5 different trips this past fall/winter and never had any kind of smoke or even an odd smell come from it.
RhoZeta is offline   Reply With Quote
Old 01-12-2015, 08:53 PM   #7
CAT-RN's Avatar
Bad or wet wood?? Other than that I'd go with dust on the heat element.
Russell.
CAT-RN is offline   Reply With Quote
Old 01-12-2015, 09:09 PM   #8
VinceU's Avatar
Thanks,
Ken
Very doubtful it's electrical in nature, a fault would burn open the first outing....or blow a circuit breaker.
Old 01-13-2015, 06:40 AM   #9
KennyGolub's Avatar
Thanks to all for a reply.
I hope I don't have a senior moment and forget to post what I find when I do get into it this spring.
Ken
