Old 11-26-2017, 12:21 PM   #1
Mbh818's Avatar
Something Growing?
Winterizing this afternoon and came across this under a bunk window. Raised growth on the wood under the paper. Sliced open one of the raised bumps and looks like hard black fungus or something. Anyone see this before? They are hard as a rock. Click image for larger version
ID:	157224Click image for larger version
Mike Hollar
2014 Berkshire 390BH-40
2012 Chevy Equinox - TOAD
Mbh818 is offline   Reply With Quote
Old 11-26-2017, 12:41 PM   #2
CZNEDY's Avatar
That is the glue underneath after being exposed to water. Probably coming in the window seal.
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 11-26-2017, 01:29 PM   #3
If glue, heat carefully with a hair dryer and use a wallpaper seam roller.
2017 Berkshire XL 40A & 2017 Ford Focus SE
I Built and Fly - Van's Aircraft RV-12
Ham Radio - W9EAA
MartyQ is offline   Reply With Quote
Old 11-26-2017, 05:45 PM   #4
Dragonship Captain
Oscarvan's Avatar
May want to investigate the window. Sounds like a re-seal could be in order.
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 11-27-2017, 06:19 AM   #5
CZNEDY's Avatar
I had that happen to our flagstaff fifth wheel a few years ago. The window seal had failed and water was getting in through the Windsor and into the wall. Easy fix, just takes some time to take it out, reseal and put back in.
2020 S.O.B.
Old 11-27-2017, 12:05 PM   #6
Dragonship Captain
Oscarvan's Avatar
I've had it happen on several units I've owned, all the old style flange windows. Every time it turned out that the Elkhart employee that put it in didn't care enough to do it right.
Old 11-28-2017, 12:38 AM   #7
Mbh818's Avatar
Ok. Thank you everybody for the feedback!
Mike Hollar
Old 12-07-2017, 04:42 PM   #8
I'm having same problem in my 2015 Berkshire XL 40RB on the dinette slide (window on the end of slide). For months, I keep getting a whiff of what smells like wet cardboard. Finally figured out that when it rains and slide is open, water if pouring off my sagging slide awning directly onto the window sill and it's leaking/running down the inside wall. I have starting noticing those "bumps" on the wallpaper too! Guess we're going to have to pull the window and seal it up.
Junior & Jackie
2015 Berkshire XL 40 RB
Chesterfield, VA
RV4J is offline   Reply With Quote
Old 12-07-2017, 07:22 PM   #9
Dragonship Captain
Oscarvan's Avatar
While this is not the solution to the problem, it can be an interim stop gap. Level the bus so that the water misses the problem area until you get it fixed.
