Old 04-12-2016, 07:12 PM   #1
Sometimes a ring just isn't enough
The rear in our 390RB was a hurting unit for places to hang towels with only a ring. Added (2) 24" towel bars. One was a piece of cake on the outer wall which seems to be pretty solid. The other I wanted to hang on the wall between the bedroom and the bathroom but only has 1/8" paneling, screws that hold the hardware to the wall would strip out faster than it took you to get it hung.
So I marked it out on the wall and used a 2" hole saw to drill holes large enough to get some backing slid and glued into the wall to screw hardware into. The trim piece for the bar was about 2 1/4" so it would cover up the 2" holes. Came out nice and strong. Took a couple of hours not counting letting the backing glue dry over night.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 04-12-2016, 07:14 PM   #2
Joe & Lori
Old 04-13-2016, 07:05 AM   #3
Pinn's Avatar
Pretty Nifty. So how did you brace the wood while the glue was drying?
2013 Flagstaff 27RLWS - Chole'
NC
Pinn is offline   Reply With Quote
Old 04-13-2016, 07:13 AM   #4
Who Dares, Wins
doc73's Avatar
He stood there and held the string!
J/k
Looks good. Pretty ingenuitive.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 04-13-2016, 11:54 AM   #5
D_B Travelers's Avatar
Very clever!
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
D_B Travelers is offline   Reply With Quote
Old 04-13-2016, 12:04 PM   #6
Good idea.
Not sure I would have tried that without seeing someone else do it first, though! Takes some guts to drill a 2 inch hole in your wall.
2011 Traverse LT, 3.6L, FWD
Old 04-13-2016, 12:11 PM   #7
An alternative approach...
Looks really nice!!... Instead cutting the large holes in the wall, I have found anchors at Lowes that are designed for mounting things to hollow core doors. These worked well when I needed to reattach some lights that pulled out of the underside of cabinets. I think they would work for mounting objects such as towel racks to the walls.
statdoc1 is offline   Reply With Quote
Old 04-13-2016, 12:12 PM   #8
Not sure what the OP did, but in this scenario, I would've used another block on the outside screwed to the inner block to pull it tight to the wall.
Great idea though...!! props to the OP.
foretm is offline   Reply With Quote
Old 04-13-2016, 12:47 PM   #9
Great ingenuity.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 04-13-2016, 01:29 PM   #10
First, you need strong string. Tie a loop on the string sticking through the wall so that it is very close to the wall. Make the loop large enough for an approx foot long sturdy stick. Slide the glued block through the wall, then pull it into position with the string. Insert the foot long stick into the loop and wedge it against the outer wall with spacers to hold it out until the glue sets. When you are sure the glue is dry, test it to make sure it is firmly glued, then cut off the string at the hole opening. Pretty slick!
PenJoe is offline   Reply With Quote
