The rear in our 390RB was a hurting unit for places to hang towels with only a ring. Added (2) 24" towel bars. One was a piece of cake on the outer wall which seems to be pretty solid. The other I wanted to hang on the wall between the bedroom and the bathroom but only has 1/8" paneling, screws that hold the hardware to the wall would strip out faster than it took you to get it hung.
So I marked it out on the wall and used a 2" hole saw to drill holes large enough to get some backing slid and glued into the wall to screw hardware into. The trim piece for the bar was about 2 1/4" so it would cover up the 2" holes. Came out nice and strong. Took a couple of hours not counting letting the backing glue dry over night.
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
Looks really nice!!... Instead cutting the large holes in the wall, I have found anchors at Lowes that are designed for mounting things to hollow core doors. These worked well when I needed to reattach some lights that pulled out of the underside of cabinets. I think they would work for mounting objects such as towel racks to the walls.
Pretty Nifty. So how did you brace the wood while the glue was drying?
First, you need strong string. Tie a loop on the string sticking through the wall so that it is very close to the wall. Make the loop large enough for an approx foot long sturdy stick. Slide the glued block through the wall, then pull it into position with the string. Insert the foot long stick into the loop and wedge it against the outer wall with spacers to hold it out until the glue sets. When you are sure the glue is dry, test it to make sure it is firmly glued, then cut off the string at the hole opening. Pretty slick!
Not sure what the OP did, but in this scenario, I would've used another block on the outside screwed to the inner block to pull it tight to the wall.
Great idea though...!! props to the OP.
This is a good option if you pre drive the screw hole. If you don't, you will be pushing pretty hard against the string to get the screw started and the piece behind the wall will have a tendency to spin and cleaning the glue off. The static method below works.
I don't have a Berkshire but I do have hollow walls and used these anchors to secure the towel bar and toliet paper holder to my hollow walls. The double towel bar was 24" but had to cut it down to fit on the wall....Easy mod and very secure.
Used some liquid nail ( good amount ) then pushed it into the hole, hanging on to the string for good measure. Lined it up in place and held pressure with the screw for a couple of minutes and pretty much tacked up and stayed there. Waited overnight to let adhesive dry before finishing.
Also had these come with the bars I bought. I just didn't trust them with the paneling being barely 1/8". But I saved them !!
First, I would have drilled a hole in the backer just large enough to thread the string through, threaded the string, then tied a large knot behind the backer. The problem with trying to use a outer block with a screw to hold it is preventing the backer from spinning and losing the bonding glue. Ref to my above post that has worked for me. The stick and wedges are statics.I learned this trick when trying to patch larger holes in drywall.
Looks good Joe. Couple of other thing to consider. I put two towel hooks in the back bath. One on the narrow section of wall between the shower and closet it's real Handy. Another shower hook at the right hand of the closet on the section that is about 4 inches wide.
